Philips Magnavox 27MS343S 27" TV Logo
Posted on May 29, 2009
Help unlock child lock on tv.
Do not know code to get child lock UNLOCKED. I would like to watch pg14 and older type shows. ThaMp3Doctor Rank: Guru Philips Expert Rating: 85%, 3348 votes 0711 twice, then the new code - double-check the onwer's manual, however, sometimes 0,0,0,0 and 1,2,3,4 work; 0711 is the Magnavox universal Comment posted on Jun 07, 2008 I thought of a better idea: 1 Press MENU to show the on-screen menu. 2 Press VOL+ or VOL- repeatedly until SET is highlighted. 3 Press CH+ or CH- to highlight CHILD LOCK. 4 Press VOL+ or VOL- to choose ON or OFF. Choose ON to disable all the buttons on the front of the TV. CHILD LOCK ON will appear briefly on the TV screen each time you press a button on the front of the TV. You can still operate the TV with the remote control.You can still use the POWER button on the front of the TV, but only to turn off the TV (not on). Set CHILD LOCK to OFF to cancel this feature so you can use the buttons on the front of the TV again. 5 Press TV/AV/EXIT to remove the menu from the screen.
  • 7 more comments
  • ioandimit854 May 29, 2009
    I did so several times, but nothing happened.
    No results.
    I followed steps 1 to 5, but without any results. When I pressed the MENU nothing happened.
    I shall gladly pay provided that I have the child lock unlocked.
    Is there anybody who has a tv set like mine? Unfortunately, I haven't got the handbook or any other papers about this tv set. Can anybody help me?
    These solutions did not work.
    Nobody can assure me that by trying your assistance plans the Child lock will be unlocked, since so far your "solutions" have not proved to be usefull.
  • ioandimit854 May 30, 2009
    I did so several times for the past three days without any results. I mentioned my tv set is a Sony made in Finland, as it is written on it; but when I checked with the service, they said this tv set is not a Sony, since its code is FX71U1RMOEV, serial no.: 4064919. They said it must have been made by Finlux. The remote control I have been using with this tv is a PILOT P3029. I have no manual of the tv set. I do hope somebody might know the key to unlock the child lock of my tv set.
    You sent me an e-mail that does not refer to my television set.
  • Anonymous Mar 30, 2014
    in phillips smart tv youtube is locked (my child did) how i can unlocked?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 31, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1555
Points
5
The solution is so simple!
Press the POWER (RED) button and the TV/AV button simultaneously - hey presto! the child lock will switch off and you will have your TV back working properly.
Anonymous
Level 1:
  • Posted on May 19, 2012
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1555
Points
0
Thanks. It works for me. I pressed power button and tv/av from remote for 5 sec. Then pressed power button. It was working.. Then went tl lock screen and off parent lock.
Thanks for the solution you provided
How to unlock the child lock for panasonic tv tc 20lchow to unlock the child lock for a panasonic tv model tc 20lc
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Unlock procedure and to override the password lock to many popular brand TVs are given.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Lost child lock code and it's asking for it...,.HELP?
If the previous user never used a child lock function, how do this now activated? Anyway, to reset this set, you have to know about the child lock code. There is some details about, how to unlock the child lock, its repair manual will have the procedure. Check this link. It has details about these matters to many brand TVs. http://electronicshelponline.blogspot.com/ Pull up older posts there, either by its left side bar, or see it in Timslide option.
2helpful
2answers
The child lock is on my tv hitachi older model. i have no remote and the tv is turned off.. how do i get it back on to remove the lock???
The child lock on a TV can be a wonderful thing. A parent sometimes cannot be present for the duration of a kids' show, so the child lock ensures they can't watch programs that are off limits. The lock can, however, cause unwanted trouble--if it gets accidentally turned on and you don't know the code, you can find yourself unable to fully enjoy the full range of available television stations. Follow a few easy steps you'll be back to watching regular TV in no time.
Instructions
Locate the manual for your television. Though slightly embarrassing, accidentally turning on the child lock to a TV is a common problem. The section In the manual about how to set the child lock feature will also explain how to unlock it.
Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A common code is "0000."
Unplug your television for a few minutes. The internal battery of the TV is what helps remember what your code. If the TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code.
1helpful
Hi i have a samsung tv n im with bell but i forgot my password for parental control... help??!!
The child lock on a TV can be a wonderful thing. A parent sometimes cannot be present for the duration of a kids' show, so the child lock ensures they can't watch programs that are off limits. The lock can, however, cause unwanted trouble--if it gets accidentally turned on and you don't know the code, you can find yourself unable to fully enjoy the full range of available television stations. Follow a few easy steps you'll be back to watching regular TV in no time. Instructions Locate the manual for your television. Though slightly embarrassing, accidentally turning on the child lock to a TV is a common problem. The section In the manual about how to set the child lock feature will also explain how to unlock it. Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A common code is "0000." Unplug your television for a few minutes. The internal battery of the TV is what helps remember what your code. If the TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code.
How do i remove the panel to get into my 47" Vizio HDTV?
Parental code not working on sansui television
Instructions
1helpful
Try this website: www.usermanualguide.com there is probably a section in the user manual on how to reset a lost/forgotten child lock. Good luck.
3helpful
5answers
Nokia 6288 unlock
Hi, I have a Nokia 6288 locked to the 3 network. Is there a code to unlock this phone?
1helpful
Forgotten password
Your tv is switched on and locked , blue screen and shows keys. A tv with activated child lock can only be unlocked after an 4-digit code is punched in.
Reset of child lock is as followed :
Determain chassisnumber type on type plate on the back of TV.
example: CUC xxxx ( xxxx = 4 digit number).
TV's CUC 6300, 6301 and 6310: bullet.gif Press cursors (blue arrows ) in sequence : Right, Left, Down , Up, followed by OK
TV's with chassis CUC 2003, 2005, 1805, 1825 t/m 1827, 1842, 1894, 1952, 1962, 1983, 1984, 1806, 1828, 1829, 1830, 1836, 1929, 2020, 2021, 2030, 2031, 2033, 2050, 2058, 2059:
bullet.gif Punch in universal code 7038 in. This code ends the child lock
TV's with Chassis CUC 1832, 1930, 1931:
bullet.gif Punch in universal code 7038580. This code ends the child lock Greetz and good luck, and PLS let me know if it works
Arni
43helpful
7answers
my TV is show " child lock please unlock" and i repeatedly attempted and ther is no feasibility .
and i want help please help mee
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
