The throttle is operated by a cable from the pedal to the engine throttle. That cable is either broken or has come loose from the pedal or the engine throttle. Check the pedal first. If the pedal does not have any return spring and falls to the floor the cable is most likely the problem. If you are familiar with the engine components and can see the throttle and cable you could have someone try to operate the pedal without the engine running. If it has come loose from the throttle you should see it move. If not you and appears to be connected to both the throttle and pedal the cable is broken. You will have to have a new cable installed if it has broken. Good luck.
Thanks for using FixYa.
