Intervideo MediaOne (BWC100108900060000) for PC Logo
A
Anonymous Posted on Jan 16, 2014
Intervideo not working properly with windows 7
InterVideo WinDVR 3.0 was running on Windows Xp SP3 32 Bit. But it will not run on Windows 8 64 Bit. What should I do?
Sometimes it will work if you run the program in compatibility mode. Right-Click on desktop icon or launch icon and there should be a "troubleshoot compatibility" May have to try a few different settings until it works.
25helpful
2answers
I use InterVideo WinDVD version 5 on my VAIO desktop computer from 2005. I actually has bought this computer to have possibility to watch DVD discs RAM format, which I'm getting from Panasonic Video...
If this same software worked previously then I would reload the software. If that does not do it then your laser mechanism may have lost its ability to properly focus on the disk surface of ram disks.. There may also be a firmware update that will improve the playback characteristics of your player.
Driver
For DVD drives, no special driver software is required. The drives will work with generic drivers provided with all standard operating systems out of the box.
However, DVD movie playing is *not* done by a driver, it requires an application installed on the PC.
For Windows, AFAIR only Windows 7 can play DVD movies out of the box, using Windows Media Center.
All other versions of Windows require a commercial or free player program, e.g. WinDVD (Corel) or PowerDVD (Intervideo) or VLC (VideoLAN, free).
For burning data or movie DVD, also an application program is needed. Windows Vista and later have some limited support for ISO and UDF files systems written to DVDs. Personally, I like CDBurnerXP for data, and Slysoft's CloneDVD / AnyDVD combo for video.
1helpful
Madame, Sir, I subscribed for CorelWindvd9 after a month trial. I payd 29 ? for it, but I cann't open the programm. An additionnal key is asked after de seriesnumber is submitted. I deleted all of the...
Hello and welcome to FixYa . In order to re-install WinDVD 9, remove all traces of WinDVD manually only delete the folders if they exist, and if allowed.If you cannot delete a folder, try renaming the folder by adding .old to the name of the folder. You will need to show hidden files and folders on the computer on XP go to Start, All Programs, Windows Explorer,tools, Folder Options, View, Hidden files and folders, Show hidden files and folders. Using windows Vista Start button getopencontent.aspx?assetid=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33&documentset=en-us&renderkey=xml, Control Panel, Appearance, Personalization, Folder Options, View, advanced settings, Show hidden files and folders, OK. The following folders will need to be erased.
Go to My Computer Use Start button, or on the Desktop. On Vista, Computer. Double click on C: drive, Documents and Settings and the folder named after your username.
When you reach the "InterVideo" folder, there will be a DVD9 folder, which is the one you are looking to erase. Note -This folder may be named Corel\DVD9 instead of InterVideo\DVD9 Erase the following folders Go to C:\Program Files\InterVideo or Corel delete the folder DVD9 Go to C:\Program Files\InterVideo\Common delete the folder Bin Go to C:\Program Files\InstallShield Installation Information delete the folder {E3993D46-AE3F-402E-9F9D-EEBDFBEC3564} Go to C:\Program Files\Common Files delete the folder InterVideo Go to C:\Program Files\InterVideo\Common\ delete the folder Bin The second place to remove WinDVD 9 settings is in the registry.
Go to Start, Run type in regedit click ok. left hand column will be a list of items double click on HKEY_CURRENT_USER double click Software and InterVideo At the very end, when you reach the InterVideo folder,erase the DVD9 folder, by right clicking on it, and hitting Delete. Erase the following HKEY_CURRENT_USER\Software\InterVideo delete DVD9 HKEY_LOCAL_MACHINE\Software\InterVideo\ and DVD9 HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Uninstall and {E3993D46-AE3F-402E-9F9D-EEBDFBEC3564} Restart the computer. Go to Start Run type in "%temp%" and hit Ok. Erase as many files as possible .In the "Edit" menu, click Select All, go to the File menu click delete.Say yes to delete Reinstall your software and it will accept your key. Hope this gets you going. Please Rate Me. And you can always Ask Me.aymloekh0fg4hpz2e87n86udvs4fowqwshuaaaaasuvork5cyii=
I just formated my computer and now my windvd 5 doesnt work it will open up in a window but will not play movies or doesnt have the control window
if you formatted it with a recovery disk try inserting dist again while running windows as a administrator and try reinstalling the program. otherwise you have to pay the $80 for the new InterVideo WinDVD 9. ($40 for basic player)
Media converter missing a file
mabey QuikTime .com? also need windows media plr 10 or better
Intervideo windvd.
try playing the dvd in windows media player, if it plays in that programme, then the intervideo programme is faulty.
Top Intervideo Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Intervideo Computer and Internet Expert? Answer questions, earn points and help others
