Tv works fine except no remote control functions
waynejman, I have the same exact problem, can you tell me what your outcome was?
SOURCE: The remote operates all the units except for the TV's vol, channe
There are 2 possibilities: either you have a stuck front panel button, or the remote sensor is bad.
You can eliminate the button issue by removing the front speaker grill and access panel and disconnecting the button assy wiring harness.
There is a plug/socket connection there that you can easily disconnect. If after disconnecting the control panel, you still have no remote, its the sensor. Its located behind the screen assy mounted behind the CRTs. You will have to remove the screen assy to get to this.
If you're not up for this, a service company will charge you $300 or so to replace the sensor for you.
michtech
SOURCE: My remote will not work with my TV (Mitsubishi
the crystal probally broke when fallen down,slammed down.goto w mart universal 15$
SOURCE: Remote Control doesn't work
It may be the sensor in remote or tv. The only way to tell is to get an orgional replacement from manuafacture, or get a universal. Much cheaper and easier than testing or replacing sensor.
SOURCE: My Mitsubishi WS-5511 TV will not receive commands
Are the front panel controls on the tv working? If yes then either the tv's remote sensor has failed or the remote itself has. Does the remote have the functionality to control any other device, like a DVD player? If yes then is it working fine? Please answer these questions so that I can help you deal with this problem.
