The washer door wont shut or lock My frigidaire affinity is only 2 years old. Error code says door is open, and washer will not start. Serviceman replaced latch today, and washer stays locked when plugged in. He wants to replace the control board. is this nece$$ary???
I appreciate your post, Trent!
Based off the information you have provided your Frigidaire washer is displaying an error code of E41 and the door is locked and will not open. An E41 error code means that your main control board thinks the door is open. I would recommend performing a reset on your washer and you can do that by disconnecting power from your washer for at least ten minutes. If that does not help correct your issue it could be a possible problem with your door lock assembly, control panel, or wiring harness. You may need to seek assistance from a professional technician to avoid unnecessary part purchases. I hope this is helpful to you. -Matt
