Generac Guardian Generator Oil Pressure Switch 0d9235b Logo
Posted on Jan 17, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can oil pressure switch be affected when rep;acing sparkplugs and wires on 1993 ford ranger 3.0 motor?
Car does not show any oil pressure after replacing plugs an d wires
tebrown507
Level 2:
Sergeant:
  • Expert 415 Answers
  • Posted on May 23, 2014
tebrown507
Expert
Level 2:
Sergeant:
Answers
415
Questions
0
Helped
110792
Points
506
You probably knocked a wire loose for the oil pressure guage when you were changing the plugs. Check all connection and it should work.
1993 Ford Ranger extended cab pickup. Oil guage showed low oil pressure while on local sall road and then truck stopped running. No warning, sputtering, etc... Check Engine light can on at the same time....
this could be the distributor pole piece, you will probably have to have someone read the computer for ignition codes to solve it. if you are by an AAmco trans shop they will read the codes for free.
What is the oil capacity for a 1993 ford ranger 3.0L v6
Hi!!
Five quarts of 20W50 Hi Mileage Motor Oil is what's is recommended for your vehicle.
Good Day!! Don't forget to rate this post!!
1helpful
Wiper problem-93 Ford Ranger XLT,2 wheel drive,3.0 v-6.auto. Only have high speed,no more intermitent,no longer returns to start position-HELP
probably the motor but chaeck this first G3 CHECK CIRCUIT 58 FOR BATTERY VOLTAGE
  • Unplug wire harness connector.
  • Set wiper switch on low.
  • Check Circuit 58 for battery voltage key on.
arrow.gifVoltage OK
CHECK for malfunctioning wiper motor. Perform low speed current draw test. SERVICE as required.
arrow.gifVoltage not OK
CHECK for:
  • Open connector.
  • Malfunctioning switch.
  • Malfunctioning governor.
  • Open wire Circuit 58 (W).
2helpful
Why won't the oil and temperature gauge work on
you should switch the temperature sensor and oil pressure sensor you had on your first engine,because your new engine must come with the light indicator dashboard so the sensor of your new engine are not compatible with your gauges....lipak!...
1helpful
Oil sending switch location on a1993ford ranger
most oil sending units are located on driverside rear of engine block or located right near or at oil filter
My Oil Pressure gauge is working erratic, want to replace the sender, but where is it? V6 3.0 auto 2wd
It's on the right(passenger) rear corner. It has one wire connected to it. To verify that you have the correct sending unit, if you disconnect the wire and start the engine, the oil pressure gauge will either stay at 0 or will peg out.
Where is the power steering sensor located on a 1993 ford ranger 4.0 super cab? (or is it called the power steering pressure switch?)
The power steering pressure switch as its called threads in to the power steering pressure hose most of the time it is close to the power steering pump, I have also seen them at the lower point of the pressure hose close to the rack and pinion.
5helpful
2answers
Ignition wiring
firingorder6a.gif firingorder6.gif 1991-1994 2.9L and 3.0L Engines Firing Order 1-4-2-5-3-6 1995 And Later 3.0L V-6 With DIS Ignition System Firing Order 1-4-2-5-3-6
4.0L Engines Firing Order: 1-4-2-5-3-6 DIS Ignition System
Top Generac Electrical Supplies Experts
vince
Paul Bade
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
