Question about Dell OptiPlex 330 Desktop Desktop Computer
Bluetooth enable Having problems turning on or connecting to other Devices
    New Friend:
  • 10 Answers
Bluetooth is line of site so nothing can interfere with the connection...also other electronics can interfere with the signal.
Have you activated pairing sequence?
Posted on Jan 17, 2014
6ya staff
SOURCE:
Having a problem pairing my iPhone 6 to my Tx-sr333 receiver. Iphone just grinds and can't find Bluetooth.
Hi Don,
Pairing is necessary when using the Bluetooth-enabled
device for the first time. Before starting the procedure, learn
how to enable the Bluetooth setting function and to connect
with other devices on the Bluetooth-enabled device.
1. Press BLUETOOTH on the remote controller.
The unit enters the pairing mode and the BLUETOOTH
indicator starts flashing.
2. While the BLUETOOTH indicator is flashing,
complete connection on the Bluetooth-enabled
device in the nearby area within about 2 minutes.
If the name of this unit is displayed on the Bluetoothenabled
device's display, select this unit. Paring will end
after a short time.
???? If a password is requested, enter "0000".
???? When connecting the unit to any other Bluetoothenabled
device, start pairing by pressing and holding
BLUETOOTH until the BLUETOOTH indicator starts
flashing. This unit can store the data of up to ten
paired devices, Thanks, JT
Mar 09, 2015 | Onkyo Audio Players & Recorders
Tip
How to turn Bluetooth on and off on a BlackBerry Tour
The BlackBerry Tour comes with Bluetooth capability, but in order to connect to a Bluetooth device, you have to enable the Bluetooth functionality. When you're not using a Bluetooth connection, disable Bluetooth to avoid other devices from connecting to your BlackBerry.
- To turn Bluetooth on:
From the main home screen, press the BlackBerry button (to the left of the trackball) to go to your Home folder. Scroll down until you see the antenna icon for Manage Connections and click on it. A pop up list will appear; find Bluetooth on the list and click it to put a check in the box next to it. "On" will appear next to Bluetooth, and the Bluetooth icon will be displayed in the upper right corner of the screen. Your BlackBerry is now in Bluetooth mode, where it can connect and pair with other Bluetooth-capable devices.
Bluetooth can also be turned on from the Options folder, under the Home folder. Select Bluetooth from the list and when the screen comes up saying "Bluetooth: Disabled," press the BlackBerry button and then select Enable Bluetooth. If you've previously paired your Tour with other Bluetooth devices, the list of those devices will appear.
- To turn Bluetooth off:
From the home screen, press the BlackBerry button. Scroll down to Manage Connections and select it. In the list that appears, click Bluetooth to uncheck it and disable Bluetooth functionality.
You can also turn Bluetooth off by clicking Options in the Home folder, selecting Bluetooth from the list of options, then pressing the BlackBerry button and choosing Disable Bluetooth.
on Jan 14, 2011 | RIM BlackBerry? Tour 9630 Smartphone
Bluetooth enable
Bluetooth technology allows enabled devices to share information and data without having to rely on a wired connection.
To pair other Bluetooth devices with your HP Pavilion, you must first make the computer discoverable by turning on the Bluetooth antenna.
HP includes the wireless assistant to help you manage the various wireless features of your computer.
Click "Start" and type "wireless assistant" into the search box.
Click the "HP Wireless Assistant" entry in the list of results.
Locate the "Bluetooth" entry. Click the "Turn On" button in the "Bluetooth" category to enable the Bluetooth antenna in your HP Pavilion.
http://bizsupport1.austin.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c01948661&printver=true - DeviceOn
Nov 28, 2013 | HP Pavilion Computers & Internet
How do i get bluetooth working on my aspire5535 laptop
Activate the Bluetooth features of your Acer Aspire to unlock your laptop's wireless function. Bluetooth technology allows your computer to control and share data with external devices without having to use a connection cable or download drivers.
In order to establish the connection with other enabled devices, you must first enable the Bluetooth antenna so other devices can locate your computer.
Press the "Bluetooth" button found just above the keyboard.
The LED above the button should illuminate.
Click "Start," "Control Panel" and "Add a Device."
Your Acer scans for other Bluetooth devices in the area.
Click the name of the device in the window that appears, and click "Next" to establish a connection with the external device.
Microsoft bluetooth support
http://support.microsoft.com/kb/883259
Aug 05, 2013 | Acer Aspire 5535-5050 Notebook
My biuetooth does not work properly in my acer aspire5750
Aug 05, 2013 | Acer Aspire 5500 5570-2609 Laptop
Enable bluetooth
Aug 03, 2013 | Acer Aspire One D150-1587 Netbook
A friend connected a android phone's bluetooth to my itower. it worked, but now my iphone bluetooth does not connect. Can anyone please help me!
Pairing with iPhone
  1. Connect the iPhone Dual Dock or iPhone Bluetooth Travel Cable to a USB 2.0 port on your computer (not on the keyboard).
  2. Connect iPhone and the headset to the dock or cable. The headset pairs with iPhone automatically.
Pairing iPhone Bluetooth Headset with another Bluetooth-enabled deviceTo pair the iPhone Bluetooth Headset with another wireless device, such as a Bluetooth-enabled phone or computer.
Step 1: Set the headset to be discoverable
  1. Turn off the headset.
  2. Press and hold the headset button for about eight seconds, until you hear the startup tone and then five quick high beeps.
    The headset is now discoverable and will remain so for about five minutes. The status light blinks while the headset is discoverable.
Step 2: Turn on Bluetooth on the other device and search for devices
  1. On the device, turn Bluetooth on and set the device to search for other Bluetooth devices.
  2. On the device, choose iPhone Bluetooth Headset and enter the PIN code 0000.
See the instructions that came with your other Bluetooth-enabled device for more information about pairing it with Bluetooth devices.
Apr 13, 2013 | Apple Soundlogic Itower Speaker Works W/...
Acer Aspire 3618AWLCi bluetooth
Bluetooth technology allows your computer to control and share data with external devices without having to use a connection cable or download drivers. In order to establish the connection with other enabled devices, you must first enable the Bluetooth antenna so other devices can locate your computer.
Press the "Bluetooth" button found just above the keyboard. The LED above the button should illuminate. Click "Start," "Control Panel" and "Add a Device." Your Acer scans for other Bluetooth devices in the area. Click the name of the device in the window that appears, and click "Next" to establish a connection with the external device.
Feb 03, 2013 | Acer Aspire Computers & Internet
Hi every time i turn on mu vaio pc a message tell me that "BTWUIEXT.exe has stopped working" and because of this i cant use my peripheral blutooth devices like cellphone and etc. also another...
To Fix this you can try the following below:
Method 1:
Check to see if the Bluetooth services are enabled. To do so, follow these steps.
a. Click on Start
b. Type "services.msc" (without quotes) and press enter.
c. In the list find Bluetooth support services and double click on that.
d. Ensure that the service is both set to automatic and started.
Method 2:Check to if these are the settings you have. You can set several options for how your computer finds (or is found by) Bluetooth enabled devices.
a. Open Control Panel by clicking the Start button and then clicking Control Panel.
b. In the Control Panel search box, type Bluetooth, and then click Change Bluetooth settings.
c. In the Bluetooth Settings dialog box, click the Options tab and do any of the following:
o To make your computer discoverable to Bluetooth enabled devices, select the check box for "Allow Bluetooth devices to find this computer."
o To allow you to add Bluetooth enabled devices to your computer, select the check box for "Allow Bluetooth devices to connect to this computer."
o To be notified when a Bluetooth enabled device is trying to connect to your computer, select the check box for "Alert me when a new Bluetooth device wants to connect."
Alternatively you can go to the device manager and make sure all drivers are installed for the driver.
Nov 23, 2017 | Computers & Internet
I have blackberry 8110 and it ask me for a passkey
Blackberry 8110
Bluetooth technology troubleshooting:
Common Problems
I cannot type a passkey on a Bluetooth enabled device
If you cannot type a passkey on a Bluetooth® enabled device, the passkey might already be defined.
On your BlackBerry® device, in the Enter passkey for <device name> field, try typing 0000.
My list of paired Bluetooth enabled devices does not appear
Try performing the following actions:
• Verify that Bluetooth® technology is turned on.
• Verify that you have added Bluetooth enabled devices to the paired Bluetooth enabled devices list.
I cannot pair with a Bluetooth enabled device
• Verify that your BlackBerry® device is compatible with the Bluetooth® enabled device. For more information, see the documentation that came with the Bluetooth enabled device.
• Allow the Bluetooth enabled device to discover your BlackBerry device. In the Bluetooth setup application, click Allow another device to find me.
• Turn off encryption for Bluetooth connections between your BlackBerry device and the Bluetooth enabled device. In the device options, click Bluetooth. Click a Bluetooth enabled device. Click Device Properties. Change the Encryption field to Disabled. Press the Menu key. Click Save.
I cannot share contacts with a paired Bluetooth enabled device
• Verify that your BlackBerry® device is paired with the Bluetooth enabled device.
• Verify that, in the Bluetooth options, the Address Book Transfer field is not set to Disabled.
• Verify that your BlackBerry device is connected to a Bluetooth enabled device that supports the Handsfree profile or the Object Push profile. For more information about supported profiles, see the documentation that came with the Bluetooth enabled device.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thank you.
Feb 01, 2010 | RIM BlackBerry ® 8830 Cellular Phone
Dell OptiPlex 330 Desktop Desktop Computer  Logo
32 people viewed this question
Ekse
Alun Cox
Thomas F. Schneider
