Reebok New York Giants Eli Manning Jersey Logo
A
Andrew Posted on Jan 17, 2014
Electric panel Not sure if it was the cold room the bike was in but plugging it in heard a noise and bang......when its plugged in goes to clock mode and double beeps when buttons are pressed it had been working fine til then....took the circuit board out and one of the small black tubes had blown literally off where could i buy a spare board for it any other way to fix it.
Greg
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Feb 25, 2014
Greg
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
366
Points
How to open and lock to use i-run Reebok?
My bike sounds like it's plugged up
Carb needs cleanin..put som BG from amarine or rv store in tank..it has strongr solvents then partstore cleaner. Nevr leave gas in bike for longperiods..it gums up fuel system..always drain n run engine til it dies. Also clean electrical connects n plugs too
1helpful
While cleaning the inside drum and turned the drum by hand. She heard a "loud noise" and will not turn. The control panel will come on andselect the mode, but when start is pushed nothing happens.
When you rotated to drum you caused to belt to pop off the pulley .it has a safety switch so it won't run if belt breaks . With unit unplugged remove top than control panel than front panel to access bottom to put belt back on just enough room for hands to fix inside
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
www.tomsguide.com/forum/60895-6-help-high-pitched-noise
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
Goes into sleep mode and clock comes up
Try to unplug set and plug back after a while.
How to find out compression problem on a 2003 kx 250
Just cause the piston looks fine dosent mean the rings are still good did you do a compression test if you don't have one buy one they are great to have with 2 stroke bikes put the cylinder head back on and cover spark plug hole with finger it should first **** a bit then should blow finger off the hole the compression should be greater than 120 psi of a 125 not sure on the 250 rule of thumb if you have less than 120 your piston or rings is pooched..
My freezer is located in a garage that is staying hot in these 90 degree temps. I just heard a noise coming from it, looked and stuff was thawing. Husband unplugged and noise has stopped fills like cold...
I would first check to make sure the the condenser coils are free of debri and there is not something against the fan.
Did the noise sound electrical or mechanical or a hiss. A hiss is most likely a freon leak or a compressor blown (usually not worth repairing). A mechanical sound could be something blocking a moving part like a fan. Electrical could mean about anything.
I would check the condenser grill and then plug it back up and try to tell where the noise was coming from.
Loud banging noise when machine goes into spin mode. sounds like it is banging on the side. Please help !
Usually this is an out-of-balance condition caused by too much weight on one side of the tub, move the clothes around and try again.
2helpful
94 Accord Banging/knocking when i turn
check the axles for leaking boots or dry axle joints....replace if necessary...also make sure all brake caliper bolts are all installed and correctly torqued
2helpful
Samsung clicking on and off but not coming on
The bang you heard was probably a capacitor. Since you are still hearing the TV attempt to power on, your power supply and it's fuse are likely fine, but if the capacitor was on the mainboard, the TV would require service unfortunatley.
Top Reebok Sport & Outdoor - Others Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Reebok Sport and Outdoor - Other Expert? Answer questions, earn points and help others
