I've tried unplugging the wii and trying to sync it like everyone says so, but it still won't work. I'm really aggrivated! Someone please help!!!
Have you tried a temporary sync?
If you don't know how to do this then all you gotta do is:
* With a Wii remote that is already synced Press the Home Button.
* Pick Wii remote settings, located at the bottom.
* Select Reconnect.
* Press 1 & 2 on the Rock Candy remote and see if that works.
Sadly this only lasts till the Wii is turned off.
I don't know if it works for the Rock Candy remote, but I hope it does until a more permanent solution turns up for you.
SOURCE: Problem getting wii GUITAR working with RockBand 2 after a resync
first of all you should make sure you have fresh batteries and then try the special resynch via the red dot like button on the inside of the controller (press it at the same time as the one in sd card slot) if that doesnt work try just moving closer to the wii at far distance the controller signal gets weak. if its not that then its a hardware issue
SOURCE: how to sync drums to wii rb2
If you look on the USB Dongle. If there is a blinking LED that means the Dongle lost connection with the drums. Hit the Black button and all should be fine.
SOURCE: Rock Band wireless guitar won't sync with Wii
press the sync button on the back of the wiimote and on the wii consle by the sd card slot (should work if not then like u said junk guitars put out for xmas)
SOURCE: wii ROCK BAND DRUMS WONT CONNECT. They were working.
is there a sync button on the drum set? if so, hit the sync button on the drums and then hit the sync button on the Wii. This will attempt to re-sync the signal of the drum to the Wii console. This has to be done for any new device that gets added to the Wii. Every so often, the Wii will lose connection with the device and has a hard time reconnecting. Sometimes this connection just has to be reset by resyncing the devices. If that doesn't work, you may have a bum product and have to buy a new one. Walmart has a replacement plan starting around 5 bucks depending on the product where, should your product fail within a year, you can order a new one on their site free of charge and have it shipped to the store for pickup. I recommend this for any high price console peripheral. So basically, my advice is to try and re-sync the drum set to your wii via the sync switches on the 2 devices. If that doesn't work, consider replacing. I hope this helps.
SOURCE: replaced dogle on wii rock
To sync the guitar to your Wii, plug the white dongle into one of the Wii’s USB ports first. Press down the guitar icon button until it flashes blue. Press and hold the sync button on the dongle and then press and hold the sync button beneath the whammy bar on the guitar. The Wii will then assign the guitar to one of the open controller profiles and you can start playing.
Here's what to do. I've had this happen many times.
1. Open up the SD Card compartment on the Wii.
2. Open up the battery cover on the remotes.
3. Press the red Sync button on the Wii, and then on one of the remotes.
4. Repeat for whatever remotes need synced.
This will make every remote act like the P1 remote. For temporary syncing, just go into the Home Menu and click Wii Remote Settings. Click on another option(it'll say to press 1 and 2) and follow the instructions.
Oh its notworking for this game... Then its most likely the same problem with that you get with Rock Band.
Load game by disk not USB
