Question about Kyocera FS-1016 Printer
Clear replace mk message kyocera fs 1370dn - Kyocera FS-1016 Printer
Anonymous
SOURCE:
Copier_God
Brian
  • 57 Answers
SOURCE: message stating install MK
You have done more than 300,000 pages. I wouldnt waste your money on a Maint Kit, just stretch it out by doing the following.
Press Menu/Ok (Main menu)
Go into [>>Service]
Then press the right arrow.
Then find [>> Maintenance]
Press the ok key, then it will show [>> Maintenance?]
Press the ok key twice, and it will reset all the counts on your consumable components (Drum, Developer, Transfer Roller, ETC)
Posted on Oct 16, 2009
PaulPaulJone
  • 95 Answers
SOURCE: kYOCERA fs-1920 Has the message instal
It means the page count has triggered this message.
You _should_ get a maintenance kit.
But if you simply can't take the time/money, you'll find a new menu item in the menus after service. the new item is 'maintenance', get to there and press enter. (May need to press enter twice), the menu item, flashing light, and install MK message will all disappear.
Posted on Sep 08, 2010
ikkenom
  • 10406 Answers
SOURCE: Kyocera FS-4000DN is showing install
> without buying a Maintenance Kit ?
Either you buy the kit, or you sell the printer "as is" on eBay, after buying a new printer.
Posted on Jan 19, 2011
y_karpova
y_karpova
SOURCE: Kyocera fs 1750
Paper jam
Posted on Jan 25, 2013
Andrew Peto
SOURCE: my kyocera fs-1370dn suddenly says it is missing a developer unit when the developer unit is there and was just working
Check that the toner you are using is genuine Kyocera, also that the toner hasn't run out, this is normally a toner related issue.
Posted on Mar 07, 2013
Can you use a Kyocera FK-170U fuser unit in place of a FK-150 fuser unit?
No the FK-170U fuser will not work in a printer that is compatible with the FK-150 fuser unit. I found a Kyocera FK-150 Fuser Unit available on Amazon here: https://www.amazon.com/Genuine-Kyocera-FK-150-302H493032-Kyocera/dp/B00GOO57M2 . Other sites have third-party replacements.
The FK-150 fuser is the correct fuser for the FS-1028MFP, FS-1128MFP, FS1350DN, among others. The FK-170U fits the following Kyocera printers: FS-1035 Mfp, FS-1135 Mfp, FS-1370DN and FS-1120D. There are a few other printers. The design changes means they can't be substituted.
I hope this helps.
Aug 01, 2018 | Kyocera Office Equipment & Supplies
Where is developer unit in kyocera fs 1370dn
the developer unit for this printer looks like this.
26367533-y50xtmg3b3sor10el1acrrt1-1-0.jpg The unit can be found under the toner cartridge.
Here is a link on how to remove the toner cartridge.
okm2000 de Kyocera FS 1370DN 1370 1350 1320 Tonerwechsel Kopierer Drucker...
Best regards,
Marius
Nov 22, 2016 | Kyocera FS-1370DN
What does Call service 4000:0047918 mean?
it means that the durm is not sitting correctly!
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Feb 18, 2016 | Kyocera FS-1370DN
Install MK Kit Kyocera FS-9130 How to reset MK Kit Counter
you can reset the counter but on the falcon engines if you go past the maint. cycle they will eventually fall down and print solid black copies.
Feb 04, 2016 | Kyocera Office Equipment & Supplies
Resetting for replaced MK kyocera fs 1135
press numeric keys 1087 1087 , then 251
Checking/clearing the maintenance count Description Displays, clears and changes the maintenance count. Purpose To check the maintenance count. Also to clear the count during maintenance service (replacing the maintenance kit). Method 1. Press the start key. The maintenance count is displayed. Setting 1. Select [M.CNT A] using the cursor up/down keys. 2. Change the setting using the cursor left/right keys or numeric keys. 3. Press the start key. The count is set. Clearing 1. Select [CLEAR] using the cursor up/down keys. 2. Press the start key. The count is cleared. Completion Press the stop key. The screen for selecting a maintenance item No. is displayed. Item No. Description Description Setting range Initial setting Maintenance count 0 to 9999999 0
May 26, 2015 | Kyocera Office Equipment & Supplies
KYOCERA FS 1370DN 7990 0088329
Empty the waste toner from the back side of the drum unit. Then remove and reinsert the waste toner sensor connector from the controller assy (main pwb).
Jun 02, 2014 | Kyocera FS1370DN Laser Printer
My kyocera fs-1370dn suddenly says it is missing a developer unit when the developer unit is there and was just working
Dec 21, 2012 | Kyocera FS-1370DN
Kyocera FS-4000DN is showing install MK; Can the problem be fix without buying a Maintence Kit for $532?
Jan 19, 2011 | Kyocera FS-4000DN Laser Printer
KYOCERA fs-1920 Has the message instal MK coming up? Dopes this mean order a maintenance kit?
Sep 08, 2010 | Kyocera Office Equipment & Supplies
We have a Kyocera FS3830N - message install MK -
MK is the maintenance kit. You can check the Kyocera site to find out where to get a new kit and how much they are:
http://usa.kyoceramita.com/americas/jsp/Kyocera/products_printers_details.jsp?pid=12331
Most of the time the message is just displayed because the machine has reached a certain number of pages, but it should still let you use it normally.
May 27, 2010 | Kyocera Mita FS-3830N Laser Printer
Kyocera FS-1016 Printer Logo
7,159 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Marvin
Marvin
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
