SOURCE: vertical lines across my entire screen
My 42" Samsung Plasma HDTV HP-R4252 has a 2" vertical strip of green pixels down the right side of the screen.
My 3 year warranty with Circuit City expires in Nov 2008.. so I hope I'm covered.. can't call until the morning.
Samsung said it might be a logic board problem.. but they want almost $2000 to fix. I might as well buy another TV if Circuit City can't fix it.
SOURCE: vertical lines on screen
Be sure the TV has no problem by playing a DVD player. If problem remains unchanged, call for service because a few boards could involve to. In the worse case, panel should be defective.
SOURCE: Vertical Line started on left side of HDTV, and now
This problem is down to the actual LCD or plasma screen, if this shows as the screen warms up and stays on then the screen will need to be replaced, you should go back to your retailer (not manufacturer) and report this problem, depending on the store and how long you have had the tv, the tv can be replaced for a like for like tv at store as this is not a cheap standard repair.
SOURCE: colorful vertical lines on screen
more likely to be bad LCD panel (very expensive), but you can try replacing the LCD controller first (around $80~100).
Sounds like a panel defect. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1000 posts to different brand TVs now. Pull up older posts there.
