My display screen has purple color to in and lines runing thru display. I have never dropped the camera but this problem suddenly appeared on display i too have purple lines on my display and small eye viewer ( z 812 IS ) kodak says this must be accidental damage like drop or water. My camera has been used 5 times in a year and always in the case fully protected. never been dropped or left anywhere that could damage it.... they want 100.00 plus shipping and handling flat rate even if it a 5 dollarpart...... second time this happens to a kodak.....will buy a cannon>>>problem fixed
The lens isn't connecting to the mobo correctly, put some pressure on the lens (sounds bad but it works for me haha) it will work correctly until you shut it down for a while. Do not take it apart and attempt to fix it, it doesn't help ( I thought maybe the screws that held down the lens were loose or that the connectors needed to be cleaned but nope) a replacement lens should solve it, but why buy one of those when you can just put pressure on the lens before every use?
Your display screen is going bye bye or, you need a new back lite. thier is no way i can help you fix it, you are going to have to buy a new camera or take it in.
