Belt is loose and dvd door doesn't open or close,need to see where that belt goes back on for the door
The door would not open all the way for the dvd slot--i opened up the player and there is a small belt loose--trying to find the right place where it goes--the door will not open or close
f the tray won't open or close properly, check the belt for dirt or
wear. Then check the tray for misalignment. If needed, remove, clean,
lubricate, and reinstall the tray following the instructions in the
owner's manual. God bless you
there is a belt which is driven by a motor to open or close the tray. u place the disc on the try and the try loads the dvd/cd into the mechanism. the belt is loose & needs replacement. you have to open the cover & find the belt on the mechanism & replace with slightly shorter length of belt.
There is a small belt under the loading tray which would have gone slack ( loose ) and the sound you hear is it slipping on the motor pulley. If you are confident you can remove the mechanism and turn it upside down and access this belt. Dismantle only if you can get the spare belt or your efforts will be in vain.
Hello
Its loading belt is loose and so the tray do not close properly. Replace the loading belt. Loading belt can be located under the tray connected between loading motor and loading gear assembly. Check whether there is any break in gear wheels too. If so replace them too. Tray is not close properly is your DVDs problem. OK.
Hello
Either your DVD players Laser Pickup Unit or its loading belt have faulty. First replace the loading belt. It can be located left front inner side of the DVD mechanism, and can be accessable from outside when tray is opened. In some sets it will be not accessable from outside, and to replace it, mechanism as a whole should be dismandled out. If this does not help, replace the Laser Picup Unit, and its strip wire, which goes to the main board from Laser Picckup unit. OK.
ok! that is mechanical problem! you have loose belt drive change it! or mechanical switch or timing switch that sensor to open or close. clean all the switch. you found the switch under the tray of the CD plate.
It is called the slider assy. The slider moves the laser assy back to home or start position. It is a small belt underneath or there is gunk or hair in the gear mechanism. A very common problem with CD/DVD players/recorders. Very good though that you saw it was not comming back to home place. I wish I had a manual to assist you but I do not. Im telling you the most common problems with the slider mechanism. Good Lck
I had the same problem. It started after I plugged a PS2 into the system using the A/V cable ports in the front. I discovered just by unplugging the cables the door opened again.
