Question about Ricoh Aficio CL2000N Laser Printer
Ricoh CL2000 SC486
Can you tell me what this error code means and how to clear it. Thanks Error light up, display shows "ready", when print, the paper jam and display "SC 486 power off on, if reoccur call service"
  • Anonymous Mar 27, 2014
    jamming in fuser unit and error code sc 486
  • 22 Answers
It is the problem your cartridge sensor chip.You change cartridge unite & buy new cartridge than solve it
Posted on May 30, 2009
Anonymous
SOURCE:
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
Printer jams when printing and I ricoh cl2000n error code sc486
sc486 is a solenoid error with the black drum unit. The most likely culprits are a bad engine board and a bad drive unit, neither one of which is cheap unfortunately. You should contact your local service technician and have them take a look at the printer to see which component is causing your problem.
Dec 10, 2010 | Ricoh Aficio CL2000N Laser Printer
My printer Ricoh aficio cl3500n does not print and all the lights on. Why?
The first step is to turn the machine off and then turn it back on. Do all the lights come right back on, or is it okay until you try to print to it?
If all the lights are on, there should be an error message appearing on the display. It might say out of paper, or out of toner, or a cover open, or it might show a code (such as "sc 501").
What is the code or error message that appears?
Jul 09, 2010 | Ricoh Aficio CL3500N Laser Printer
Ricoh Afiicio CL2000 Color register error.
You can try to reseat the color PCU, but you may have to replace it. Also, make sure all of your color toners are seated properly.
Jun 28, 2009 | Ricoh Aficio CL2000N Laser Printer
Colors aren't blending
We have a problem,after the calibration on the begin the printer gives an error: "Color regist. error",but the toners are full ! How to resolve?? Thanks in advance.
Mar 05, 2009 | Ricoh Aficio CL2000 Laser Printer
Our 4506 message says load SEF letter
Check if the orientation of the printing document matches to the paper available in the copier's trays.
Load SEF letter: means Load Short Edge Feed letter (landscape).
Good luck and please rate me, thanks.
Jan 30, 2009 | Ricoh 4506 Copier
Ricoh CL2000 SC486
Realizar a troca do BK Solenoid.
Ele está localizado dentro do driver onde estão as engrenagens, ao lado esquerdo da impressora atrás da placa BICU
May 21, 2008 | Ricoh Aficio CL2000N Laser Printer
Add Black Toner Msg.
Try taking out the cartridge and reinstalling it. Was this a original ricoh toner cartridge or a el cheapo cartridge off the internet?
Mar 19, 2008 | Ricoh Aficio CL2000 Laser Printer
No confirmation sheet
first i need to know if it receives or copies,if it don't.that code is is heat lamp(fuser) problem.
Sep 13, 2007 | Ricoh FAX3800L Plain Paper Laser
Error Message: Replace Black PCU
I'm not sure how to obtain one, but "Black PCU" stands for Black Photoconductor Unit, and according to a manual for a different Ricoh printer model, it should be fairly simple to replace if you can find one.
Nov 10, 2006 | Ricoh Aficio CL2000 Laser Printer
Ricoh Aficio CL2000N Laser Printer Logo
1,732 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
