Maytag MFI2067AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
A
Anonymous Posted on Jan 17, 2014
Two problems-- the fridge is freezing food and the ice maker and water dispenser do not appear to have water
5 Related Answers
Anonymous
  • 790 Answers
  • Posted on Dec 29, 2007
SOURCE: Ice Maker Issues
HELLO!!!
THIS MAY HELP U ...
http://www.applianceaid.com/icemaker.html#overflowing
Anonymous
  • 1314 Answers
  • Posted on Jan 02, 2008
SOURCE: Ice Maker Overflowing
i would recommend changing the water valves as they may be sticking or leaking now you can take the icemaker loose get a small baby bottle short the terminals to cycle water fill catch it with the bottle and see how much water it dumps should be about 4 ounces if the valve leaks will over fill the ice maker over a period of time say the valve is leaking a few drops at a time and the bail arm has the icemaker shut off because its touching ice in the bin but the water just keeps dripping down the fill tube till it runs over did you replace the whole icemaker or just the motor module
Anonymous
  • Posted on Sep 08, 2008
SOURCE: Maytag MSD 2432GR Water not feeding into Ice Maker
one possible solution is that the ice maker water valve has failed (solenoid). I would try switching the wires on the water valves and see if water goes into the ice maker when you push the water dispenser button, if it does the valve is ok. If you go this far go ahead and fill the ice maker with water ( about half to two thirds full) switch wiring back as first found and see if maker will freeze and dump ice, if it does ok, if not the problem is probably in the ice maker.
Anonymous
  • Posted on Apr 09, 2009
SOURCE: maytag side by side fridge water dispenser not working
there are two water inlet valves on the back of refrigerator, one for icemaker the other for water in door. the valve for the water inlet is plugged or the soelinoid coil is bad. replace faulty valve, usually about 20 to 30 greenbacks at the appliance parts store
Anonymous
  • Posted on Sep 29, 2009
SOURCE: ice maker will not dispense water or ice.
sounds like maybe the switch that is press to release water not working so it doesnt sent the signel to let water out dispenser
How can I make my Samsung Food Center produce more ice?
Contact after sales support. Could be an issue with the compressor but it should be covered by manufacturers warranty
Jan 18, 2018 • LG Dryers
My Frigidaire refrigerator works find; Freezer stays cold but doesn't freeze food or ice
Its defrost assembly parts issue or the compressor is getting waek indication.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Freezing food in frig. , not making ice .
Freezing food in the fridge also freezes the water line for the ice maker.
You have a thermostat problem. Get a new thermostat fitted.
1helpful
2answers
My Aman side by side quit dispensing water. It
Does your fridge have a small tank inside the food compartment? If so, the water may have frozen in the tank and the problem can be solved if you take a blow dryer and warm the tank. That's what happened to mine and with a temp adjustment to keep the food compartment a bit warmer, the water doesn't freeze.
1helpful
FROZEN WATER FILTER - UNRELIABLE TEMPERATURES
About the dual water control valve the side that feeds the ice maker could be defective. Fill the ice maker with tap water and let freeze. If it dumps and does not refill the water control valve will need replaced. Here is a link to the water control valve.
WR57X10032 Water Control Valve
As far as the temperature control here is a link to the Temperature Control Here=>
WR55X10095 Temperature Board Encoder Below are some photos. If I can help answer any questions let me know, Sea Breeze [email protected] 6b49f39.jpg053ba1a.jpg
Fridge and freezer not working right
remove and refix the regulator inside the fridge....
3answers
Ice maker not working
So your not getting water from the dispenser either??? Yes the water filter can be the source of your problem. Let me know if the water is coming from the dispenser.
1helpful
The water filter keeps freezing and food in door and on shelves keeps freezing.
clean lint from coils in back. could also be low on refrigerant (freon)
Top Maytag Refrigerators Experts
vince
Johnny 1000
Jesse Walters
Jesse Walters
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
