Screen says remove misfeed open top cover, press form feed remove misfeed. There is no jam?
SOURCE: clear misfeed (A) on display screen
There is a thin black plastic armature with a tiny flag on the end of it. that flag movement trips a switch everytime a copy passes over it. If this arm is not seated right, then the flag is not dropping between the switch and which is why the jam lite is staying on. if you open the right sided acess jam door and look straight in, down in the lower right corner you should see this small black box shaped switch, it has 2 thin white wires connected to it By removing the paper tray, you can reach in and try cleaning it with canned air if its not the arm and flag hung up, dust in it is causing the problem.
SOURCE: Ricoh Aficio AP2000 Laser paper jam
Found solution myself.. The paper sensor arm with flag and sensor was missing from the exit side located on the fuser assembly.. Customer apparently broke off prior to calling for us to repair. Solution-replaced fuser assembly clean and tested works great
SOURCE: Remove Misfeed B Fusing Unit Error- After 1 page is printed
just open the printer and check for any dislocation of the sensor or levers.
SOURCE: gx3000 printer showed remove misfeed
inside it will be small pice of paper, remove it. and will be normal.
