Question about JVC AV-56WP30 56" Rear Projection Television
Hook up jvc flat screen to comcast cable box
Connect to comcast set top box
2 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 103 Answers
SOURCE: hd signal not being picked up
your comcast box is not hdcp compliant.this signal tells the tv it isok to display the image.It is similar to video copy guard
Posted on Mar 06, 2007
Is my Magnavox 1T HDD rECORDER COMPABILE WITH cOMCAST cable Box ?
If your Comcast box has a composite output, you'll be able to record SD shows. Use RCA composite video and audio cables between the box and the recorder. You'll have to set the box to the channel you want to record and leave it on. Then set the HDD/DVD unit to record from video input (L1 rear, L2 front) for the appropriate length of time. The manual explains this. The manual is available from Funai who built the unit with the Magnavox name: http://funaiport.com/upload/MAGNAVOX/Manual/MDR537H_EN_OM.pdf . See pages 19 and 42. If your TV and/or cable box only have a limited number of video inputs/outputs, you may need to daisy chain the composite video cables from the cable box to the DVD/HDD unit's video in. Then connect another composite cable from the DVD/HDD video out to the TV.
This Magnavox unit can only read analog (NTSC) cable video signals without a set top box. You will not be able to record a show and then watch another with the cable box.
I hope this helps.
(I know that my cable system's box has a composite video out. So it does work with most of the Comcast boxes. Many of the manuals are available here: http://customer.comcast.com/help-and-support/cable-tv/cable-box-user-manuals/ )
Sep 25, 2014 | Televison & Video
HOW DO i CONNECT MY RCA RTD325W SURROUND STYSTEM THROUGH MY COMCAST BOX AND MY TV
Video out on rtd325 to Video in on TV, set tV to correct input source, not red/white cables to Audio or AUX INPUT on the rtd325 and run those to Audio out on the comcast box, set rtd325 to AUX fcuntion when watching comcast
Oct 29, 2013 | RCA Dvd Home Theater System Rtd325w Remote...
I have an Arris modem from Comcast that gives me phone and internet service. Prior to going to Comcast for telephony I used a regular, off the shelf, modem and I could connect to my Direct TV sat box via...
comcast use 10.0.0.1 for ip address, I think
check direct tv box for internet settings for it's ip address should 10.0.0.2 maybe call directv maybe they could further.
May 14, 2017 | Arris Touchstone 450a (CM450) Modem
TRYING TO INSTALL DIGITAL SET-TOP BOX WITH DVD AND TV
Hi ccraigo
To answer your question;
Your motorola will connect directly(not through the dvd) to the tv set into one of the input ,(preferably using hdmi or component cables for hd) and the dvd will use a different input,
All you have to do then is switch between which one you want to watch.
Hope this help Cheers
Apr 20, 2010 | Pioneer Televison & Video
How do I connect to Sharp HDTV and Comcast cable
Your dvd recorder only has rca, red white yellow inputs it wont allow you to record in HD, although you can play your comcast box any hd, regular digital through and record. Hook up the comcast box if HD through preferably HDMI if not get one from comcast. The HD box is the only box that allow HDMI, component and regular RCA and some RF out. This way you can play HD to your set but also record through RCA or RF again will not allow for HD record unless its TiVo. Hope this helps
Jan 07, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
Can't get my hannspree remote to work with comcast
10030 for the comcast dvr remote. Code is from NEC
Oct 02, 2009 | Hannspree HT09 28 in. LCD TV
Connect to comcast HD receiver
use 2hdmi cords -tv to cable box and the cable box to the davis10 than go to the setting on the davis10 and turn on the hdmi
Jan 04, 2009 | Sony DAV-IS10 System
TV Setup
Are you using a top of set box? If not make sure the set is set for cable then do a auto program/ channel search. The tv most likely is set for ANTENNA .. If you have a top of set box it could be the problem..
Apr 21, 2008 | Insignia 37" LCD Flat-Panel HDTV
Trying to connect my xbox
hook it up in place of the cable box...rf adapter or use the rca plugs and get barrel adapters to connect them
Oct 30, 2007 | Microsoft Xbox Console
JVC AV-56WP30 56" Rear Projection Television Logo
Top JVC Televison & Video Experts
Todd Hill
Todd Hill
matt martin
matt martin
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
