Question about Sanyo DP50747 50 in. Plasma TV
My tv has a timer on or energy saver
Evevy 10 mins my tv keep cutting off it keep saying energy saver ( trying to save energy on my tv )
  • 29 Answers
Reset it to factory
Posted on Jan 18, 2014
Testimonial: "sorry this is not what im looking for im taking about my TV energy saver or timer do you get the picture now."
  • 1 more comment
  • Julio Derrick
    Julio Derrick Jan 20, 2014
    i say to reset yu tv to factory reseting and everry thinh
  • Julio Derrick
    Add a Commentg will coming normal yu get that
  • Julio Derrick
    if yu dont' know how to reset it go menu
Anonymous
SOURCE:
I use my flat screen for a computer monitor it shut,s down if not used for 10 min. how can I fix it
Change the settings for the power save options in the TV and see if it has some timer for no signal.
Alternatively in the PC you can select a screen saver that has a moving image which means PC will always give a video signal even if it is not used.
Sep 07, 2014 | Coby LEDTV1926 19 in. TV
How to disable energy saving on KitchenAid Range
The Energy Saver Mode deactivates the display to reduce energy
consumption.
To Activate the Energy Saver Mode:
1. Press and hold OPTIONS for 3 seconds. "Energy saver on."
will appear in the upper text area.
2. The setting will be activated after 5 minutes.
Any cooking function may be used with the range in Energy
Saver Mode by simply selecting the desired function.
To Deactivate the Energy Saver Mode:
1. Press and hold OPTIONS for 3 seconds. "Energy saver off."
2. The clock will reappear in the display, and the range can be
operated as usua
Oct 10, 2012 | KitchenAid Ovens
Remove screensaver from TV
Hello
You are refering about energy saving function I thinks. To energise this function, surf through its menu and come towards energy saver.
This power saving feature reduces the backlight
brightness level. The options are:
OFF-the feature is off and the power consumption
is normal.
LOW-power saving level is low and the backlight
brightness level is lower than normal.
HIGH-power saving level is high and the backlight
brightness is set to the lowest level.
1 Use the CURSOR Up or Down keys to highlight
Energy Saver. Press ENTER.
2 Use the CURSOR Up or Down keys to select Off, Low,
or High.
NOTE:The Energy Saver settings level varies with
the Picture / Sound mode.
OK.
Feb 20, 2011 | Sanyo 42 in. LCD TV
Superswitch programmable wall light switch - when timer is in off position lights glow dim when using energy saving bulbs.
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/in-wall%20timers/ej351c.aspx
Manual say 'incandescent' light bulbs only.
What can I control with my EJ351C? The EJ351C timer is to be used with standard base incandescent light bulbs only! It should not be used to control lighting such as:
  • Compact Florescent
  • Energy Saver
  • Flood lights
  • Halogen
  • Mercury Vapor
  • Christmas lights
  • Candelabra bulbs
Oct 16, 2010 | Intermatic Programmable 24 Wall Switch...
Tv takes 30 min to cut on... but when it does no picture shows.
LOL sounds like you just need a new TV buddy, there are multiple components that are going out, first start with the green lines or "pixelations" these are caused by the tv no longer being able to regulate the electricity in those pixles and are as a result 'Open'. The 10 minute things is more of a energy conversion thing and sound and video on and off are connection issues (internally) so take it to a repair shop but if the price to fix is greater than 1,000 you should be willing to scrap it for a replacement. who knows the shop might buy it off you for cheap...
Good Luck
This is my Fav...
pricey though but can keep an eye on ebay for half price divorces.. :D
http://www.samsung.com/us/consumer/detail/spec.do?group=televisions&type=televisions&subtype=lcdtv&model_cd=LN52A750R1FXZA&fullspec=F
oh and my site
www.hoosierpcrepair.com
Jun 22, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Which setting on an Energy Miser saves energy?
OFF is the Energy Saver mode.
To reduce moisture, there is a heater around the door seal that stays turned on, using energy. If you switch to ON, you use more energy.
It is confusing though.
Jan 17, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Can't get the air conditioner to cut off and on
Check to see if it has energy saver option on unit or timer. If you have, and you have tried to use it you may need to call the manufacturer. If it does and you haven't used it yet, try setting energy saver. It also helps the A/C last longer by preventing unit from freezing up from overuse.Note- make sure you set the temperature for a setting that is comfortable for you for day and night.
Aug 05, 2008 | Haier hwr10xc6 Air Conditioner
Keeps turning off
As for the 10-20 secs ,tv turns off .......I have one of those ......Im still trying to fix mine, without buying a new board ,I will post results!
Jun 09, 2007 | Sylvania 6626LCT 26 in. LCD Television
Sanyo DP50747 50 in. Plasma TV Logo
120 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
