Health & Beauty Logo
Alan Johnson Posted on Jan 18, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Motor bike qingqi
My QuingQi mobilty 4 wheel scooter ( cant find any model details ) has been used as a golf buggy in a previous life ...it has a hand brake lever , but no cable or anthing resembling a braking system that i can see .....I assume it it is meant to have some type of electrical braking ??????....can you help with some info .....regards Alan
Rob Hill
Level 3:
  • RTO Master 1,480 Answers
  • Posted on Jan 19, 2014
Rob Hill
RTO Master
Level 3:
Answers
1480
Questions
0
Helped
517452
Points
3838
Hi Alan, any chance of a photo of the motor and read transaxle ???
Regards
Rob
www.gewizrepairs.co.uk
5 Related Answers
gewiz
Rob Hill
  • 1480 Answers
  • Posted on Jun 14, 2009
SOURCE: little gem mobility scooter brake not working properly
The throttle part has slip round, a way to test this is to put hte buggy in reverse slightly and it shoud stop, meaning that how much the throttle has slipped round. Take the top cover off and there should be a allen screen on the throttle stem, undo and readjust.
Anonymous
  • 9 Answers
  • Posted on Jun 22, 2009
SOURCE: Problems with Pride Celebrity X 4-Wheel Electric
It is often a damaged accelerator (Potentiometer). Sometimes the shaft on the wigwag breaks the contacts in the accelerator from being moved too vigorously when going over a bump too fast. A technician would need to repair this for you. Happy scooting. Regards Chris… [email protected]
Anonymous
  • 10 Answers
  • Posted on Jul 07, 2009
SOURCE: what kind of oil do you use in a mobilty scooter
you have to get the oil for gear box from an authorised service centre.
oregoon
  • 175 Answers
  • Posted on Jul 12, 2009
SOURCE: The battery takes a charge, but will not power scooter
This scooter require two batteries, not one. It is usually a good idea to replace both batteries at the same time, even though one is obviously bad, and the other "seems" okay. These 12 volt DC batteries (VDC) work in tandem to produce the 24 volts that the scooter operates on. In a perfect world, they would both live a long and happy life, but reality is that some die young, others old. Since they are joined together, the one that's going out saps the life out of the other one, so take a bullet and replace both batteries. Make sure you completely charge the scooter when you get the new ones in. Verify that your charger is working properly. To properly charge the 24 VDC system, the chargers have to have an output of about 26-28VDC. The output must be higher than the rated voltage of the two batteries put together to charge. While you have the shell off the scooter, you can see if the charger is working by measuring across the terminal on each battery with the charger off. Note the meter reading. It should be 12-13 VDC. Put it on the charger and retake the reading, and each battery should show an increase in the voltage due to the boost from the charger. After three hours, each battery should show about a 13.5 VDC reading which should hold above 12 for a good 8-10 miles. Always charge your batteries overnight, and if not in use, disconnect them completely with a full charge on the batteries.
Rich Miller
  • 46 Answers
  • Posted on Jul 11, 2010
SOURCE: NEED A REPAIRMAN FOR A 3 WHEEL BATTERY OPERATED SCOOTER IN FLORID
well it most likely the the 5k ohm potenteitometer is bad this is a common ptoblem with pride scooters if you have a screwdriver and can take it apart you can order the part online and it comes with the wire tail on it so it just plugs into the controller board the part costs about 68 dollars from pride depending on what model you have, email me and i could probably walk you through it
What is the size of a rear wheel nut for a Hillman ProHawk singe seater golf buggy please?
  • Hillman Pro Hawk GT Sport Single Seat Golf Buggy
  • Lithium (Li-Ion) & Lead Acid Battery Options Available
  • Delivered Fully Assembled & Tested
  • Modular Design Fits in Most Cars
  • Steering Wheel & Foot Accelerator System
  • 24V DC 1000 Watt Motor
  • Can be Purchased Without Batteries
  • Balloon Tyres
  • Speed 0 - 12.5 kmph
  • New Model for 2019
  • 12 Month Warranty for Buggy
What do the beeps mean?
  1. Popular Drive Medical Ventura 4 Wheel Deluxe Scooter ...
    www.fixya.com > Forum > Mobility Scooters > Drive Medical
    Popular Drive Medical Ventura 4 Wheel Deluxe Scooter ventura418cs Power Mobili ...My Go Go Elite Traveller mobilty soccer beeps when I try to go Forward.
Does anyone by any chance know what oil goes in a qingqi 49cc scooter. It has it's own little reservoir inside the seat panel. Can anyone tell me what does it take. Confused and don't know.
Hello, Qingqi. I found this article that says SJ10W-40 is best for a 49cc gas-powered scooter. http://www.ask.com/vehicles/type-oil-use-49cc-gas-powered-scooter-e2ec930521cd0a6a
Qingqi scooter
I am having the same problem and I am having a hell of a carry on trying to get the v5 for my sinnis eagle as it's down on the dvla as a Qingqi varient so I am really confused I know after doing some research Qingqi go by the name of sinnis in the UK but it's really confused me and I have been trying to get the v5 for 4 months now!!!!!
My victory 4 mobilty wont charge the green light is very faint/the charger was tested working.so why wont my scooter charge
make sure battery cables are secure at battery terminals and clean.how old are the batteries.If the batteries run down fast they are no good.a good way to test them is put scooter against some thing solid and go forward.If the battery indicator drops to o the batteries are no good.It takes about 10 hours to charge the batteries
1helpful
2answers
Can I increase the speed on my pride mobilty scooter internally?
hi,
there can be a couple of ways to do this ,
Upgrade the batteries2_bing.gif to a higher amps say 40amps to 55amps etc,
but if the controller is say 70amps, more powerful batteries will not make it go any faster so you will need to also look at the motor controller.
first what is the rating for the installed motor controller ? can that be upgraded to more amps say from 70amps to 110amps etc however you must take care here that the motor can handle the extra amps otherwise you will burn it out,
Regards
gewiz
3answers
I HAVE JUST PURCHASED A 3 WHEELER MODEL PRIDE
AXLE NEEDS GREASE!!!! DO NOT RUN IT !!! WITHOUT IT,THE PLACE U BOUGHT SHOULD HAVE BUT WERE PROBABLY BEIN LAZY
Mobility scooter
Tranz Group Limited SH.
Tranz Group Limited SH., one of the "Top One Hundred Manufacturer and Wholesaler Enterprises" in China, was established in 1998. It is a high and new-technology enterprise focusing on researching and developing, producing and selling consumer extreme motor sport products.
After more than 10 years of development, Tranz Group has about 300 workers and has entered into six dominant industries, which cover: Mopeds Scooters and ATVs Quads, Pocket Bikes, Utility Vehicles, Dirt bikes, and Dune Buggies products. Our product series are: ATV, Motorcycle, Elderly Scooters, Mopeds, Generators, Mini choppers, Mobility Scooters, Golf Carts, Manufacturer. Most of them are for export and have been delivered to more than 30 countries and districts. We are experienced in motor sports products for a wide range of internationally renowned enterprises and famous motor sports stores. "Passion, Innovation and Commitment" is the philosophy Tranz Group staff has insisted on for 10 years and will lead Tranz Group to further success and progression.
For more of our products and company information, please visit our website fastglobalsupplier.com and contact us at 1-(718)-554-0292 any time. We are sincere to welcome all the guests and friends at home and abroad to visit us.
Top RTO Health & Beauty Experts
Rob Hill
Rob Hill
Thomas Perkins
Thomas Perkins
Harsal Patel
Harsal Patel
Are you a RTO Health and Beauty Expert? Answer questions, earn points and help others
