AOC 24 Envision L24H898 1080p Widescreen LCD HDTV - 16:9 10,000:1 Logo
A
Anonymous Posted on Jan 18, 2014
Remove pedistal base from 24h898 aoc envision tv
Cant get the pedistal off
Dave Parker
Level 2:
Habit-Forming:
  • Expert 83 Answers
  • Posted on Jun 25, 2016
Dave Parker
Expert
Level 2:
Habit-Forming:
Answers
83
Questions
0
Helped
21244
Points
118
You need to remove the cover that hides the 4 screws that hold the stand to the monitor. There are 3 pieces to the pedestal base. The base plate, the pedestal, and the screw cover. To remove the screw cover, look on the back where the pedestal attaches to the monitor. There is a cover just above the pedestal. Pinch the top left and top right sides (about one inch from edge) to unclip the cover. Remove the 4 silver screws (2 on each tab) and put them in a ziploc bag to avoid losing them. Tape them to the pedestal/base and cover.
4 Related Answers
Anonymous
  • 1779 Answers
  • Posted on Nov 27, 2010
SOURCE: My Envision series AOC TV lights up, but when I
This is either a problem on the Power supply board that supplies the 24volts to the Inverter board or the inverter board my have a bad capacitor or two, or a bad transformer. It's difficult to say exactly without testing it.
budmrtn
Bud Martin
  • 11361 Answers
  • Posted on Dec 11, 2010
SOURCE: how do i remove the
Here is the user manual:
http://208.109.228.157/arquivos/produto/manual/L32W861_manual.pdf
or
http://tv.manualsonline.com/manuals/mfg/aoc/l32w861.html
See page 8 on removing the base mounting screws on the bootom side of the base.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Chi Chu
  • 8457 Answers
  • Posted on Jan 01, 2011
SOURCE: How do I change the
Look for the manual control button the said INPUT.Pushes couple times,now u will move within HDMI modes like 1,2,3.
Anonymous
  • 11 Answers
  • Posted on Aug 27, 2011
SOURCE: what is the comcast remote
Directly from Comcast.com
AOC 3,010,017,025,044
Hope this helps.
When powering on screen lights up for second then off , hear sound
You probably have a power supply problem. The electrolytic capacitors are a high failure item in these TVs. I just replaced two capacitors in the power supplies of my two AOC TVs and got both of them working again. Repair will probably be much cheaper than replacing the TV.
My 6 year old 32inch envision tv no longer has picture or sound anymore even after its properly connected to cable
Based on the brand parts may not be available and six years is better than average life for this type of set.
My Envision Series AOC TV has blue lines across the screen when its on. Common problem?
This might be a screen driver problem that cannot be easily repaired without replacing the whole screen assembly. It may be cheaper to replace your TV. Ask a repair shop for a repair quote.
Envision flat screen tv has 5 channels that don't play volume but show pic
Check the volute settigs to these channles. Check whether system set is compactable with input.
What is the comcast remote code for aoc envision tv L32w761
Hope this helps.
2answers
I have a n envision 22" flat panel TV purchased
I don't think there is still warranty for this TV. Usually, warranty last for 1 to 2 years... In summary there is not warranty for this TV, it must have expired.
To further confirm, check the receipt of purchase. The warranty duration should be stated there.
I hope you understand the above....
Good luck.
3helpful
2answers
Cant find audio output
On the earlier model AOC 32", there was only 1 audio output in the form of a digital Toslink output (fiber optic). An updated model was introduced in late 2008 which included a left and right phono audio output. The only ways to combat the lack of phono audio output on the earlier model are to either, A: Purchase an analog to digital converter online, or B: Go through a device with an analog to digital audio converter built in. Something like a stereo receiver should do this without any problem. Hope this helps.
Top AOC Televison & Video Experts
Arnie Burke
Arnie Burke
Are you an AOC Televison and Video Expert? Answer questions, earn points and help others
