GE 7 cu. ft. Chest Freezer FCM7DR Logo
A
Ali Mans Posted on Jan 19, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
GE Freezer stopped working
Freezer stopped working a few days ago. I unplugged it over night and plugged it in again the next day. The power button comes on, but no sound and no cooling.
richie46
Level 3:
Top Expert:
  • GE Master 12,962 Answers
  • Posted on Jan 21, 2014
richie46
GE Master
Level 3:
Top Expert:
Answers
12962
Questions
Helped
2941701
Points
58151
Obviously, the compressor is not running. Confirm the presence of power to the compressor itself. If it is getting power and unit does not run, you have an open motor winding OR if you have a start capacitor the latter could be defective. Let's hope that you have the capacitor because they go bad and are a lot cheaper to replace than the compressor!
4 Related Answers
Anonymous
  • 87 Answers
  • Posted on Aug 29, 2008
SOURCE: The sides of the freezer are really hot
Is it really becoming excessivly hot or is it that you just have not been aware before. Most freezers generate heat when they are cooling down (yeah ok, so that sounds crazy). It may just be the freezer working hard to lower the temperature to get back to normal operating temperature
Anonymous
  • Posted on Jan 11, 2009
SOURCE: deep freezer
I TURNED THE CONTROL TO OFF TO DEFROST MY FREEZER. WHEN I TURNED IT BACK ON THERE IT DOESN'T COME BACK ON AND THERE IS A LOUD BUZZER.
IS THERE A RESET BUTTON SOMEWHERE TO RESET THIS OR HOW CAN I GET IT TO COME BACK ON? I HAVE NEVER HAD THIS PROBLEM BEFORE AND OF COURSE I CAN'T FIND MY USERS MANUAL. IT IS A 1994 MODEL FB14 DSDRWPT.
Anonymous
  • 226 Answers
  • Posted on Apr 29, 2009
SOURCE: my brand new freezer wont freeze
I would plug it into a different plug in - not one that is on the same circuit that it is plugged into now. If the plug in is working for other things, it still may be bad and not able to handle the load of the freezer. If your freezer will not work on a completely different circuit, then there could be something wrong with the freezer, but it is not likely since two of them should not be bad. Seems to me more like an electrical problem in your location. Hope this helps you, Rick
Anonymous
  • 43501 Answers
  • Posted on May 27, 2010
SOURCE: Freezer Temp keeps getting too high
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
2answers
Bush Freezer M5085UCFR stopped working?
Si su Bush Freezer M5085UCFR dej? de funcionar, hay varias cosas que debe comprobar. Primero, aseg?rese de que est? conectado correctamente a una toma de corriente segura. Si est? conectado correctamente, compruebe que la luz interior est? encendida. Si la luz interior est? apagada, desenchufe el congelador y desconecte la tapa del termostato. Limpie los contactos con un pa?o h?medo y vuelva a colocar la tapa del termostato. Si la luz interior sigue apagada, sugerimos llamar a un t?cnico en refrigeraci?n para reparar su Bush Freezer M5085UCFR
My GE FUF14SVRWW upright freezer will shut off for no reason. The digital temperature control will be blank, the light will not turn on, and freezer isn't running. I will unplug it for a few minutes and...
Ach, digital controls! It sounds like the logic board/panel is on the fritz. No cure unless you can identify the malfunctioning component and replace it.
Freezer runs for approx. four days with operation normal. Then the temp. panel of front door displays a symbol that looks like a short L followed by a period. Then the temp. gauge and the interior light...
From what I read, the "L." that you see on the control panel indicated that the controls have been locked. According to the manual if you hold down the "alarm reset" button for 3 seconds the "L." will disappear allowing you to control the temperature again. I don't as of yet know what is causing your overall problem though...
1helpful
My kenmore freezer stopped working for about two days it had been leaking water for a few months, then it started working again?
It could be that your defrost system is faulty. If the freezer does not defrost now and then it will fill up the cooling fins with ice and get warm. The leaking could also be an indication of two much ice. Did you unplug it when it stopped working and then plug it back in?
My freeer stopped working after the temps dropped
freezers have a range of ambient temperature uses
most are plus 10c to 35c if using some units in garages etc. they just dont work...too cold for the poor things...
1helpful
heatman101
1helpful
Frigidaire upright freezer Model #FFU17C3AW1 Not keeping cold
Yes that is the correct part number.
If a new cold control does not correct the problem. Replace the compressor start relay.
Freezer/Refrigerator tempurature swinging wildly
The compressor is overheating and not starting. Could be just the start relay. If this happens again try unplugging it for about an hour then it should work for a while. Heat between doors is normal this is an electric heater designed to keep the doors from sweating. You just noticed it because the refrigerator wasn't cold.
Jun 26, 2008 • Freezers
Top GE Freezers Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you a GE Freezer Expert? Answer questions, earn points and help others
