Washing Machines Logo
Sharon Mcgregor Posted on Jan 19, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why will my dryer not work it keeps flashing and says f04
STEVEN NEUNHOFFER
Level 2:
Scholar:
New Friend:
  • Expert 187 Answers
  • Posted on Jan 20, 2014
STEVEN NEUNHOFFER
Expert
Level 2:
Scholar:
New Friend:
Answers
187
Questions
Helped
135352
Points
320
You have a bad thermistor. There can be as many as five of them. You take a volt meter and put it on that sound setting when a circuit completes. The thermistor (if bad) will have a bad circuit and not register a sound on the Ohm meter.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
What does code F04 E04 on Maytag Maxima dryer stand for?
F04 E04 means low power voltage to dryer - check both sides of AC receptacle for 110 to 120VAC on each side to ground - check breaker panel for tripped or bad 220VAC breaker. Only one side may be suppling voltage to dryer.
https://www.6ya.com/callphilipforhelp
F04 fault on a hotpoint aqualtis tumble dryer. Also 4 lights flashing. HELP!
This should be in your manual?
F04 Rear thermostat fault Advice: We recommend you call our customer service centre to book an engineer on: 0344 822 4224
The machines lights are flashing red. Error code F04 What does that mean? How can I fix it please? Thanks Tina
did you try to unplug machine fot 5 to 10 mins to reset machine? hopp this works for you
Feb 11, 2015 • Dryers
Brandt washing machine error code F04
F4, F04 is always door related.
5helpful
My Hotpoint Aquarius WF430 1300 doesn't complete its cycle, it stops after the wash & doesn't go on to the rinse & final spin. It seems to "freeze" after the wash is finished as the lights remain...
If your lights are flashing, use these codes to pinpoint the error.
These codes are reading from the top neon down.
F01....OFF, OFF, OFF, Flash, OFF.
F02....OFF, OFF, Flash, OFF, OFF.
F03....OFF, OFF, Flash, Flash, OFF.
F04....OFF, Flash, OFF, OFF, OFF.
F05....OFF, Flash, OFF, Flash, OFF.
F06....OFF, Flash, Flash, OFF, OFF.
F07....OFF, Flash, Flash, Flash, OFF.
F08....Flash, OFF, OFF, OFF, OFF.
F09....Flash, OFF, OFF, Flash, OFF.
F10....Flash, OFF, Flash, OFF, OFF.
F11....Flash, OFF, Flash, Flash, OFF.
F12....Flash, Flash, OFF, OFF, OFF.
F13....Flash, Flash, OFF, Flash, OFF.
F14....Flash, Flash, Flash, OFF, OFF.
F15....Flash, Flash, Flash, Flash, OFF.
f16....OFF, OFF, OFF, OFF, Flash.
F17....OFF, OFF, OFF, Flash, Flash.
F18....OFF, OFF, ON, OFF, OFF. Fault on control board, check Eeprom.
these are the codes and this is what they mean
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
also try checking this manual
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/WFseries_19504110305_Jan05_book.pdf
4helpful
Dryer stops & gets F04 code. ?? what is this code, can't find it in my book. Thanks LW
the F04 code refers to improper venting of the dryer.
either your vent is too long, or blocked by lint or a crimp.
dryer vents should be no longer than 10' in flexible venting or 15' in rigid venting.
alot you will find that at the EXIT port outside your house is clogged with lint. remove the lint and you should be ok.
Top Washing Machines Experts
john h
