Fisher and Paykel WA37T26G Top Load Washer Logo
Eunice Rojas Posted on Jan 19, 2014
Repair manual Display dont light up . Need to know how many times to push button for whites.
jerushy
Level 1:
Problem Solver:
  • Contributor 15 Answers
  • Posted on Jun 06, 2014
jerushy
Contributor
Level 1:
Problem Solver:
Answers
15
Questions
0
Helped
4738
Points
23
This is the user manual.
http://www.fisherpaykel.com/vault/pdfs//pdf_usecares/4112_US_Ecosmart_Washer_EN_FR_UG_lo_0109.pdf
2answers
Need a manual for a Seiko melody in motion wall click. Model # QXM123BRH
Here is a manual for the Seiko Melody in Motion Wall Clock, Model # QXM123BRH:
Getting Started
  • Insert one "AA" size alkaline battery into the clock's battery compartment.
  • Set the clock to the correct time by pulling out the time-setting knob and turning it clockwise or counterclockwise to set the time.
  • Push the knob back in to the "Lock" position to finish setting the time.
Melody Selection
  • Press the "Demo" button on the clock's front panel to listen to all the available melodies.
  • To select a specific melody, press the "Melody" button repeatedly until the desired melody plays.
Volume Control
  • To adjust the volume of the melody, press the "Volume" button repeatedly until the desired volume level is reached.
Light Sensor
  • The clock is equipped with a light sensor that will automatically turn off the sound and motion sensors when the room is dark.
  • To disable the light sensor, push and hold the "Light Sensor" button for approximately 5 seconds until the "OFF" indicator appears on the display.
  • To enable the light sensor, push and hold the "Light Sensor" button again for approximately 5 seconds until the "ON" indicator appears on the display.
Motion Sensor
  • The clock is equipped with a motion sensor that will detect movement in front of the clock and activate the sound and motion sensors.
  • To disable the motion sensor, push and hold the "Motion Sensor" button for approximately 5 seconds until the "OFF" indicator appears on the display.
  • To enable the motion sensor, push and hold the "Motion Sensor" button again for approximately 5 seconds until the "ON" indicator appears on the display.
Nighttime Silencer
  • The clock is equipped with a nighttime silencer that will automatically turn off the sound and motion sensors during a designated period of time.
  • To set the nighttime silencer, push and hold the "Nighttime Silencer" button for approximately 5 seconds until the "SET" indicator appears on the display.
  • Press the "Melody" button to select the start time for the nighttime silencer.
  • Press the "Volume" button to select the end time for the nighttime silencer.
  • Push the "Nighttime Silencer" button again to save the settings and exit the nighttime silencer mode.
Troubleshooting
  • If the clock does not operate properly, try replacing the battery with a new one.
  • If the clock still does not operate properly, contact Seiko Customer Service for assistance.
Note: This manual is for general information purposes only and may not cover all features and functions of the Seiko Melody in Motion Wall Clock, Model # QXM123BRH. Please refer to the manufacturer's instructions for complete information on how to operate and maintain your clock.
Mar 03, 2023 • Home
3answers
Clock light and temp.light fading out.what needs to be fixed
LED clock/temperature light fading an - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges.../650-led-clock-temperatur...
Aug 20, 2007 - 3 posts - ‎3 authors
The LED clock/temperature/etc control light has been becoming less ... needs to be replaced (board being the oven clock/erc/control board). Control pad temperature light out
Jun 15, 2014
Dim temp lights
Feb 7, 2014
Frigidaire range LED display is dim
Aug 28, 2009
Oven clock & light
1 post
Jun 21, 2009
More results from forum.appliancepartspros.com
Cheap Fix for a Dim Display on an Oven Control Panel ...
6helpful
I dont know how to change the time on my decathlon geonaute watch
I nearly went crazy pushing buttons, but finally got the right combination. From the normal Time Display (as you would normally use the watch, no need to push any buttons) Push and Hold for a few seconds the Lap/Reset Button. The "Set" Mode will become active. Release the Lap/Reset button when Set appears in the Display. Notice in the Display a small Arrow that points to a button, either the ST/STP or Mode Button. (Initially it will be the ST/STP Button). When you depress the button to which the arrow points, the Field Flashing in the display will be set (For ST/STP) or Changed to the next Field (When the Arrow Points to the Mode Button). Simply toggle through the fields (using the Mode Button) and set (using the ST/STP Button) as needed. You will also be offered the ability to set the Month, Date, Day, 12/24 HR, and a M-D (It stands for Month - Date, in Europe it's more common to display as Date - Month). I did not change this field since by default on my watch it displayed M - D first. The setting cycle will be finished off when you have set the various fields by again pushing the Lap/Reset Button. Not related to setting the watch, but possibly useful, the Watch will completely reset if all the buttons are pushed at the same time, including pushing the Display Light (or in the case of this watch, the illumination used for the Display Characters). Hope this helps, it worked for me.
Nov 01, 2011 • Watches
I am trying to get the Mephisto, Master, to move as white first. I have set the operation mode at +top but it still opens up game playing computor as black
My name is Paul and I can answer your question about making the Mephisto Master Chess computer play the white pieces.
1. Set up the pieces so that you are playing black or have black pieces closest to you.
2. Push the option button and push your finger or a chess piece down on square G1 making sure that you have a symbol with the appearance of a cross to the left of the word top.
3. Push the clear button once and you will recognize that the display is showing that white has the turn.
4. push the enter button one time to force white to show its first move. Now what you see in the display will not be correct but stand up and look at the display lights horizontal and veritcal and you will see that they indicate the correct piece to be moved but the alphabetical and numerical information on the LCD or the display will not match.
Follow the display lights and look the the piece symbol and you will see what I am talking about.
I haven't figured out how to make the computer show the correct information yet but when I do I will let you know immediately.
Have fun
4helpful
3answers
I have no owners manual. how do i program the garage door opener
Okay, first step is to clear any preprogramed doors or gates, engine must be off, press and hold the two outside buttons until the display confirms the operation (20 sec). this next step you will need the transmitter for the door you are programing, pick a button of the three you want to program, place the transmitter next to button and you will push them both at the same time and release, note the transmitter or hand held garage door opener what ever you call it, i dont want to confuse you ,when i say transmitter i mean the garage door opener, this must be close to buttons 1 inch at least, after you puhed and release both buttons at the same time then you are done. to program the other buttons just hold the next opener near the button and push both buttons, you dont need to hold the outside buttons again unless you want to erase all programing, good day let me know how it works.
3helpful
Hi, I need help with this brand of Roxy blue Calculator watch insurction and I got them from ebay but she dont have any booklet. I try to set the time. I can't do it so would you make simple explain to me...
Had same problem. Press and hold C (mode) until the display flashes. Then press C again (without releasing) to get to time. Press "Select" to move from sec, min, hours, days, etc. Press advance to go change the actual time.
these directions work http://www.roxy.com/graphics/uc/roxy/manuals/Roxy_manual_watch_70s.pdf if you change the following: C=C Mode A=Select B=Advance
Normal Time Setting 5.1 In Normal Display, hold C-Button for more three seconds and then push C-Button once. Tuesday flag and seconds digits will flash. Push B-Button once to reset the second to zero. 5.2 Push of A-Button once: Minute digits flash and advance by depression of B-Button 5.3 Push of A-Button once again: Hour digits flash and advance as above. 5.4 Push of A-Button once again: Month, digits flash and advance as above 5.5 Push of A-Button once again: Date digits flash and advance as above 5.6 Push of A-Button once again: Flag of weekday flash and advance as above 5.7 If push of C-Button during any changing time, Normal Display will be appeared
Jun 14, 2009 • Watches
Need a manual . the led doesnt light up so i dont know what is happening to the unit when i push the various buttons
check out
www.mobileinformationlab.com
that should be able to help.
first can you clarify what led you would be speaking of? is it the main display of the unit or the buttons are not illuminating? let me know and ill try to help you.
2answers
Samsung Syncmaster 710n no display and no LED light
The power button should be on the FRONT BOTTOM RIGHT. and there should be a little led/light next to it. make sure everything is plugged in correctly and press the power button, the led should light up, and then boot your computer.
Let me know --
If this helped please mark this thread as FixYA
Onscreen display
I had the same problem when I pushed the wrong button and didn't know which button I had pushed. The Date and Time just blinked. I could change them with the clock buttons. Then I really got frustrated. I saw the display button. I pushed it. It seemed that nothing had happened. Then I pushed it again, and part of the display disappeared. So, I pushed it again and yeah!! the whole display disappeared. So, try pushing the display button enough times to get the display to disappear. You have waited a long time for an answer. I hope you got one before today, 5-18-2009. I am not an expert, and I have no manual. But, I found a way to get rid of the display. I'll try to not push the display button again if I don't really need it. I think that you have to cancel the display before you record. I don't think it can be taken out of the playback.
Top Fisher and Paykel Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
