SOURCE: Printing mostly blue with lines across page
I have the same problem that you are haveing, I changed the ink ,both black and color, and it hasen't helped any, I wanted to get a new copy and printer machine but I don't want to get one and have the same problem. I have runined a lot of print paper trying something else new. I am open to all suggestons. thanks Ken.
SOURCE: lexmark x1180 printer all in one
Clean the contacts on the cartidge and printer ( open the replace ink door wait for the printhead to come to center and turn off power) if that does not work then replace cartridge, it might be a recycled one that they did not chane the chip.
SOURCE: Lexmark X125 keeps saying cover open change cartridge
try to make sure that the clear "ribbon" is situated correctly inside the unit, otherwise it will not communicate correctly with the moving electronics in the cartridge tray
SOURCE: printer wont print at all. error message is 50C.
Hi Try These Solutions:
its quite simple really just turn off your printer then unplug it
remove both cartridge's get like a wet baby wipe or something similar
let them sit on it for @ 10 secs then just real easy wipe the front
piece as well take the same wipe and wipe the heads in the printer well
sort of dab them dont wipe let dry for @ 10 secs put them back in (note
you will need to move your cartridges over to where load position by
hand to and back) run a cleaning test then align test , then print a
test page and wah lah works on every one i ever had to do . sort of fix
the things u know. have fun hope this eases your day or better. merry
christmas to all and to all good night in essence what has occured is
the cartridge got shorted and has dried at the surface as well. try it
any other tips you need well ask but not to many thats why i quit
giving tips like 15000 email a week blow your mind apart
or
Well, I did all that but no dice. But then I noticed that the
"protective" tape on the new cartridge had left sticky junk on the
cartridge -- but NOT on the print heads, just on a regular part. I got
rid of the sticky stuff and voila!
The
problem could be due to a communication failure between one of the printheads
(cartridges) and the All-In One (AIO) or by a short in one if the printheads. Please follow the steps
below to identify and fix cartridge issues:
Try to contact the store where you bought the new cartridge(s) and have them replace it. You may also contact Lexmark Technical Support Center for assistance (especially if you're using genuine cartridges).
