Question about ASUS MeMO Pad HD 7
Cant download itv player
I have I player on my asus memo pad but cant seem to download itvplayer?
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 131 Answers
Go to download itvpplayer to android and then instal it in you memo pad and ready vote please
Posted on Jan 22, 2014
6ya staff
SOURCE:
Reset asus memo pad kow to factory settings?
If you cant reset your phone normally try hard resetting it.
  1. First of all, download the "cleardata.zip". You can get it from support.asus.com (e.g. Asus clear zip )
  2. Afterwards unzip it to your MicroSD card.
  3. In order to turn the device off press the Power button for a short while.
  4. First of all, download the "cleardata.zip". You can get it from support.asus.com (e.g. Asus clear zip )
  5. Afterwards unzip it to your MicroSD card.
  6. In order to turn the device off press the Power button for a short while.
  7. Select Clear User Data using the Volume buttons to navigate and Power key to select.
  8. When "Please remove installation media!" inforamtion appears on the screen remove the microSD card from your device.
  9. Success! The hard reset has just been performed.
If this doesn't work use the link below
ASUS ME176C Memo Pad 7 How to Hard Reset my phone HardReset info
Mar 17, 2017 | ASUS Tablets & eReaders
The touch pad on my 10.1 inch asus memo pad doesn't work
Hoe long have you had this tablet? The fix may not be one that can be repaired without opening the case. But I would try a factory reset first.
With this problem, you will need to contact Asus.
Sep 17, 2014 | ASUS MeMo Pad Smart 10
Can you fix a bad charging port on my asus memo pad 7
Asus seems to be having some serious issues with their memo pad and if yours is out of warranty doing it yourself may be your only option. There are a few videos on you tube about this problem so I would check them out. I had to open my Asus tablet when my cat knocked it on the floor and I had a black screen. Be aware that if you decide to fix your memo yourself that you need to be very, very careful every step of the way; take pictures, write notes...whatever you need. Good luck!
Aug 05, 2014 | ASUS MeMO Pad ME172V-A1-WH 7" 16 GB Tablet...
How to connect asus memo tab to tv
The ASUS Memo Pad has a Micro HDMI port next to the Micro USB port. Get a Micro HDMI to HDMI cable and you can connect the ASUS Memo Pad to your TV.
May 23, 2014 | ASUS Eee PC T91MTPU17BK Tablet
Bypass screen lock asus MeMO pad
check your setting memo pad... uncheck automatic update...
Mar 13, 2014 | ASUS MeMo Pad Smart 10
Trying to factory restore a asus memo pad
It not power on or it have a paswoard problem ? if is paswoard remove it with yoo pc and this program mobogenie instal it in you pc then conect and instal you memo pad in the pc then go to folders ask the paawoard archive edit it and ready clear all paswoard in to you memo pad vote please
Dec 07, 2013 | ASUS MeMO Pad HD 7
My asus memo hd 7 will not take a charge or turn on whatsoever..How can I fix this..?
first open your pad check the conector to volt in 4.5v maybe need a rebulding soldering do it then close your pad and work agan vote please
Nov 04, 2013 | ASUS MeMO Pad HD 7
Turn off demo mode on asus memo pad
If it's the issue we had, that is an asus video clip plays over and over when the tablet isn't used, I found the solution. It's in fact a screesaver! so go to ASUS apps, and click screensaver, and deselect the screensaver check box.
Cheers,
Jeff
Oct 26, 2013 | ASUS MeMo Pad Smart 10
Cannot install candy crush on asus memo pad hd 7. I get unknown error code "-24".
You will need to do a factory reset on the device. This should clear up this issue & then you should be able to download the Candy Crush application again afterwards.
Oct 25, 2013 | ASUS MeMO Pad HD 7
My Asus memo pad 7 will not download paid apps
Have you tried doing a factory reset? Try doing this under the settings menu, which should clear up any issues & then you can try to download your desired apps again.
Oct 22, 2013 | ASUS MeMO Pad HD 7
ASUS MeMO Pad HD 7 Logo
173 people viewed this question
Top ASUS Tablets & eReaders Experts
Ekse
Terry
Alun Cox
Are you an ASUS Tablet and eReader Expert? Answer questions, earn points and help others
