In service mode, the washer will spin the full 1000 RPM's. However, in normal mode, the washer will not acquire full spin speed. It will cut off in High Speed mode after a few minutes also. Clothes are soaking wet when spin cycle ends. Why?
The heavy jacket prevented the washer from spinning at a rapid pace, so I added a heavy bathrobe to absorb some of the water and to balance the load. The washer then spun very quickly and drained out all the water.
Yes...they use less water...so they start, tumble, then cycle again adding more water. I use the fastest setting on all my clothes which is 1/2 hour. It also does start and stop during spinning to tumble the clothes. It speeds up as it goes thru each stop till it spins real fast. All my clothes wash perfectly on fastest cycle.
sounds like it has bounced out of balance, it may have lost level, the springs in side might have lost some of there spring, or the clutch may be getting bad. the belt might be loose as well and starts slipping when going faster.
Regulate a specific spin speed that generates excessive vibration and noise as follows:
1) Put an unbalance part (rubber) inside of the drum.
(this is a special weight that service people use. It clips into the drum. If you don't have it, throw in about 4 to 6lbs of damp laundry.)
2) Start the QC test mode (Refer to section 7-2).
7-2 says turn the washer off, then press 'spin speed' and 'soil level' at the exact same time. Then, while holding both buttons, press power to start "QC test mode"
3) Press Delay Wash button, then ' tst ' is displayed on lcd
4) Press the Spin Speed button repeatedly to select Extra High.
5) Press the Quick Cycle button, the spin speed is displayed.
6) Press the Start/Pause button.
7) Press the Beeper button repeatedly to set spin speed (600, 800, 1000, 1200 rpm) and check if there is vibration
and noise.
8) If there is no vibration and noise, increase the spin speed by pressing Beeper button.
9) If there is vibration and noise, rotate the Cycle selector knob clockwise to reduce the Spin Speed (reduce by 50
and 100 rpm). In case of 600 rpm, it can not reduce the spin speed.
10) If vibration and noise are reduced, press the Quick Cycle button to store (2 beep sounds).
* If you want to return to factory default spin speed setting, repeat above steps except step 9)
This machine has a variable spin-speed setting. You can set the spin-speed RPM (between OFF and 1200RPM) using the smaller dial located next to the main wash programme selector dial.
I hope I'm not stating the obvious, but appliance "faults" are often simple and don't require taking the machine apart or calling a service engineer. If you've already tried the above suggestion and your washing machine is still spinning slowly, please post back and I will try to assist you further.
Pump out time of 40 seconds sounds good. No ND error code and you spin up to 850RPM which is max for the machine. You have no standing water in the wash basket.... I'm scratching my head. Could you do a Spin Only cycle with that same wet wash load and set the SPIN for Max Extract. After you start the Spin Only cycle put the machine in Service Mode and watch the RPM range. This cycle sets the display to 12 minutes. Let’s see if the wash load remains wet and what max RPM is reached. ""Maybe the pump is not turning on during the spin cycle?"" You have no standing water in the wash basket correct? I feel the pump is turning on or you would have standing water in the wash basket and the pressure switch would have never indicated an empty condition (Low Level pressure switch contacts) to the Control Board. The Control Board would have stopped the wash cycle with a ND for no drain error code. The pump in the spin cycle will turn on a number of times see if you hear turn on in a Spin Only cycle I just ran a Spin Only light wash load with about 5 gallons of water in the wash basket. Timer went to 12 min.I toggled into Service Mode to watch wash basket RPM.At about the 5 Min mark (toggle in and out of Service Mode) the wash basket reached 850RPM then a few minutes later it stepped down to 830RPM to end of Spin Only Cycle.You don’t have a water valve stuck open or you would flood/over flow of the machine.Did you here the drain pump turn on several times during the Spin Only cycle? Rich
We are talking about FAV6800A or FAV9800A TL correct? If so you need these links the Service Manual and parts look up; here is the Service Manual for reference. Sears Parts Direct for reference. If your machine completes the wash cycle with no error code such as ND (No Drain) and there is no visible water in the bottom of the wash basket when you remove your wash load then I would do this test. Take the next wet wash load that is dripping wet and lets do a Quick Spin Test in Service Mode.During this test test the FAV6800A LED display model will step thru the RPM (revolutions per minute) or goal is to ensure the machine will spin the wash basket up through all Spin Cycle RPM ranges.Any RPM range above 99RPM’s will be shown with a (.) dot after the two numbers displayed i.e. 350RPM will show as 35. 550RPM will shoe 55. And so on. I’m and owner of the FAV6800A and I’m not sure what the LCD display of the FAV9800A will display. Enter into Service Mode; Page 14 of the Service Manual; below I have cut and paste the instructions.
Enter / Exit Service Mode To enter Service Mode press the Enviro Plus and Spin Only keys (simultaneously) for three seconds or until the control beeps. Now go to page 14 and enter this front panel key pad press to start a Quick Spin Test and see if the machine with that wet clothes load will spin the wash basket to 850RPM. Quick Spin Test While in Service Mode, press the Hand Wash key to start a Quick Spin Test. Quick Spin test steps are as follows: 1) Lock the lid. 2) Spin to index speed 90 rpm and hold for 60 seconds. Pump drains machine. 3) Spin to index speed 150 rpm and hold for 6 seconds. 4) Spin to index speed 350 rpm and hold for 6 seconds. 5) Spin to index speed 550 rpm and hold for 6 seconds. 6) Spin to index speed 700 rpm and hold for 6 seconds. 7) Spin to index speed 850 rpm and hold for 6 seconds. Pump out. 8) Coast down to 0 rpm chimes 3 times. Hit the Off button to get out of service mode. If the machine spins the wash basket to 850 RPM then we need to start looking further.What are your results? You can check the flow rate of the drain system by again entering Service Mode and turn the Drain Pump on in service mode.I would (hand fill) place 5 gallons of water in the machine and turn on the drain pump see page 16 for Board Output Test. Enter Service Mode and press the Delicates key.You are now in Board Output Test now press the Presoak key and the Drain Pump will turn on.If your machine pumps out the 5 gallons of water in 60 seconds or less I would say your Sump Cap, drain line connection from Sump Cap to input to the Drain Pump, Drain Pump and discharge line are all working as designed.If the Machine takes greater then 60 seconds to dump the water then you need to start troubleshooting for a drain line restriction or Drain Pump issue…...Rich
Hello smithe623 I’m an owner of the machine. I assume the machine is not displaying and error code to the LED Display? I would download the Service Manual and go to page 14 and perform the Quick Spin Test in Service Mode. Enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00” The Quick Spin Test will spin the wash basket up thru all RPM ranges starting at 90 RPM .15 =150 RPM, .35 = 350 RPM all the way up to .85 for 850 RPM.Report back on the results of the Quick Spin Test and we will go from there. You can get out of Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or press the off button on the console. Take care…..Rich
