SOURCE: there s a cd stuck inside the dvd player of my tv and wont eject.
Check the mechanism of your DVD player try Repair and Align it
SOURCE: dvd stuck in the dvd / tv
I had this same problem and fixed it too. It was from a flat torsion spring on the loading mechanism that had moved position. It hits against the chassis of the DVD housing preventing the mechanism from seating the disk on the spindle. Result is a stuck disk and/or constantly running loading motor.
Remove the one black machine screw behind the DVD player. DVD player will slide out of TV with its black plastic trim fascia from bay.
Remove two screws that hold fascia panel, remove fascia and lift off top metal cover.
With CD loading slot facing you, the problem spring (in our situation) was at the left. Also identical spring on the right side too. These are the two torsion springs near the front on sides of chassis. The helical loop on the left should be towards the top. If it shifted to the bottom, it can hit the tab with screw used to secure DVD chassis. When this happens, CD loading mech can't complete loading disk onto the spindle. If spring flips when the CD is on the spindle.... disk can't eject.
I used a pair of tweezers to gently grab the spring and "flip" it upwards by pulling it upwards. Spring will work for mechanism in up or down position, but needs to be up to avoid interence.
Solved my problem and DVD has been great since. If it flips back for some reason, then I will try attaching a small piece of plastic to the side of the chassis to contain spring in upright position only.
SOURCE: DVD stuck in DVD player, TV/DVD player combo
I have had this before, get yourself a butter knife, slide it gently into the space, and try to maneurver the dvd back a little, and while you have the butter knife in, push your open/close button, hope this works for you it did for me!
SOURCE: a dvd is stuck in the dvd player of my polaroid
if you will look under the drive where you put the dvd in there is a little pin hole push a small paperclip in there and the dvd will pop out
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
SOURCE: I have a 19" LCD
Here's what I would do in your shoes:
1)Try several DVDs, to make sure it isn't an isolated case.
2)Check the firmware version of the TV against the newest one available from Polaroid's website.
3)If you are in warranty, call Polaroid, this is obviously an issue with their TV and will have to offer you options to repair or replace this unit.
I'm sorry you are having trouble with your DVD player.
