Question about Ricoh Aficio CL2000N Laser Printer
Ricoh mp 9000 sc440 - Ricoh Aficio CL2000N Laser Printer
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 95 Answers
SOURCE: error code sc440
Black drum motor error. These machines are bad about the waste toner building up in the drum unit. You could try and take the auger out of the drum unit(very messy) and clean it out or try replacing the black pcu.
Posted on Mar 23, 2009
gggg
  • 904 Answers
SOURCE: my ricoh printer is showinf an error of sc440-2
sc440 on the CL7000 is a drum motor error. sc440-2 is specific to the color drum motor. The problem is either the motor itself, the drum gear position sensor, or one or more of the color photoconductor units. The photoconductor units you can replace yourself if you have extras -- see if that will clear up the problem.
If they don't, you'll need to contact a service technician to inspect (and replace if need be) the motor and sensor.
Please rate this solution if it was helpful. Thanks!
Posted on Sep 17, 2010
aviral_srms
Aviral Saxena
  • 1216 Answers
SOURCE: HI I am getting an error on Ricoh 1232c sc440 any
An error code is necessary to resolve the problem so you should reply me with that .
Meanwhile i give here a list of common error codes and how to rectify them
Click here for link
Thank
Posted on Oct 18, 2010
Ezrahite
Rofel Lantican
  • 2632 Answers
SOURCE: Ricoh mp c2550 has sc440-02
Welcome to Fixya. That code is color drum motor lock. Pull each drum unit out and look at the drum surface if one is not turning good it will have toner all over it. Could be that the drum is full of waste toner, but usually it is a backed up waste toner auger system. If that machine uses a fuser oil the oil has leaked down into the waste toner auger system and clogged it up.
If you have questions please let me know. Thanks for using Fixya.
Posted on Apr 07, 2011
My ricoh printer stoped printing and came up with an error code sc440-00
http://basketballgames.io/
Basketball Games, you are the all star team. Do quick match, tournament or even play against your friends in 2 player mode. Call your friend right now, set your team and get ready for super struggles which are tough from each other.
Aug 28, 2016 | Ricoh Office Equipment & Supplies
MP 9000 SC 124 What is the solutione please?
SC 124 Scanner error Check and clean white plate
Scanner error Check exposure lamp /comming on -Carl
Feb 23, 2015 | Ricoh Office Equipment & Supplies
My ricoh printer stoped printing and came up with an error code sc440-01
Possible Drum motor, or sensor - you would do best getting a professional in to repair, as self repair on these will no doubt end in issues..
Aug 28, 2014 | Ricoh Aficio 2238C Color Copier Printer
My Ricoh 2238c color copier has a SC440-01 error, what can I do?
Main motor error
The main motor starts or changes
speed. The lock signal does not
continue for 1 second within 3
seconds.
• The main motor starts. The lock
signal is detected and operation
proceeds normally. The lock
signal is interrupted for 1 second.
Causes:
• Defective main motor
• Too much load of the main motor drive
Nov 01, 2012 | Ricoh Aficio 2232C Color Copier
I have a ricoh 1232C multifunction and it has just stopped working and gives an error code sc440 " Functional Problem with the copier "
The problem is Main motor error.
The problem can be two diffrent things.
1. Defective main motor
2. Too much load of the main motor drive
Oct 18, 2010 | Ricoh Aficio 1232C Color Copier
I have this error code on my ricoh aficio cl7200 : SC 440-02
On the CL7200, sc440-02 is a color drum motor error. This error could be caused by a bad color drum unit (any of the 3 colors) or the drum gear positioning sensor, but more often than not it is because of a drum motor that went bad. There is one motor that controls all three color drums -- when this motor goes bad, you get the sc440-02 error.
Apr 23, 2010 | Ricoh Aficio CL2000N Laser Printer
My ricoh printer is showinf an error of sc440-2
Dec 13, 2009 | Ricoh Aficio CL7000 Laser Printer
Error code sc440
Mar 17, 2009 | Ricoh Aficio CL2000N Laser Printer
Paper jam leading to error code sc440-01
I think the code is a black pcu motor lock. Replacing the black pcu might fix it, but the black waste toner section could be backed up.
Jan 29, 2009 | Ricoh Aficio CL7200 Laser Printer
Ricoh Aficio CL2000N Laser Printer Logo
296 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
