I have a Maytag QuietSeries 400 and it's got a green light on beside a box with a 3 in it (where you choose your cycle) and I cannot change it to another (e.g. Normail Wash). When I try to press the start button I get an "L" in the display window. I have tried turning it off and leaving it for a half hour or so and then turn back on but the same issue persists. Any ideas?
SOURCE: filter light still on "Red"
try holding ice type and child lock together for 3 seconds that worked on mine
SOURCE: Maytag MDB7600 issues
reach inside your d/w and jiggle the mushroom shaped float switch located on floor of d/w. should move freely up and down if its stuck up(or something lodged under it your unit wont fill with water
SOURCE: maytag neptune won;t rinse
Check latch mechanism for alignment. Often operation of machine loosens latch mechanism causing internal switch for "door open (or ajar)" preventing rinse or spin cycle. Opening and closing door presses latch mechanism closing internal switch allowing for continue processing to rinse or spin cycles.
SOURCE: Maytag Dishwasher Model: MDBTT59AW
My research indicates that this is a control board malfunction, but with so many different descriptions of failure, I am left confused.
You may reference the link below to help isolate your problem.
http://www.repairclinic.com/0088_9_1.asp#Level1_9
SOURCE: Maytag dryer [electric] MED9600 lights up but won't start
Possible causes for your issue include:
Blown fuse
Timer or motor inoperative
Housing wiring not properly connected to dryer
Bad door switch
Faulty "Push to Start" switch
It would probably be best to have a professional pinpoint the exact defect.
Click Here for a very good source of information on Maytag dryers
