Question about Radio Communications
Sennheiser rs120 A few weeks ago the system would not stay tuned. I unplugged for 15 minutes as advised & it worked. Today it occurred again. After unplugging & reconnecting the on/off light works intermittently. What should I do?
    New Friend:
Problem solved - had to remove ear pad to reveal screws underneath.
Posted on Jan 21, 2014
  • Ted Borges
    Ted Borges Jan 21, 2014
    Posted in the wrong place - sorry. The user interface here could use some work.
3 Suggested Answers
6ya staff
SOURCE:
Bob Citizen
  • 520 Answers
SOURCE: I have no instructions
Here's the link to the user guide.
http://www.sennheiserusa.com/newsite/pdfs/RS_120_US.pdf
Posted on Feb 13, 2009
Anonymous
SOURCE: Sennheiser MM 50 iPhone Mic & Button does not work
I had just the same problem and if you're lucky, the solution is very simple: due to the open headset-plug of the iPhone I had a lot of dust inside. Just try (carefully!) to get the dirt out of the jack with a pair of tweezers or a strong vacuum cleaner. In my case it solved the problem. Good luck!
Posted on Jun 08, 2009
My rs120 sennheiser headset arrived Monday.i charged it for 24+hours yet am not getting more that 10-15 minutes of service time. Does headset polarity matter on charger?
Send it back it is faulty. The battery is shot.
OR
go and buy (2) AAA NiMH rechargeable batteries from here which will be far better quality and have a larger capacity than the ones you have.
AAA Eneloop Precharged NiMH Battery 2 Pack Batterybuyer com
Jun 09, 2017 | Sennheiser Radio Communications
No power sennheiser rs120
Probably a defective item, Try for a return.
Oct 13, 2014 | Sennheiser RS 120 Consumer Headphones
My RS120 will work fine but in about 10 minutes they have no sound. K
see if the sound drivers are wll installed and if it happens with another headphones
Jul 27, 2014 | Sennheiser RS 120 Consumer Headphones
Violin doesn't stay tuned
This is an intonation issue. If you can find a music store that works with violins, talk to someone there who will certainly be better informed than I am. At least they can tell you if it's worth your time to fix it, or more cost effective to replace it.
Apr 16, 2017 | Music
Coolant resevoir question
First, going two months without checking fluids leaves you open to not know when it started to get low. If you are filling the tank with gas, then you should check all the other fluids as well. By the book, you have two marks on the overflow container, COLD & HOT, normally we add coolant to the COLD level becuase of expansion when HOT it could overflow and waste coolant. So the new shop did not do anything bad, and the old shop should have advised you to check fuild levels often. In either case over two months evaporation could have reduced the coolant in the resevoir. It would be a good idea for the next few weeks to check it prior to starting the vehicle each day and not the level when cold, then check it when it has had time to warm up, such as when fueling the vehicle. Constanly having to add coolant is a serious condition that MUST be corrected soon or could lead to more serious engine failure. Hope this helps you.
Aug 06, 2009 | 2006 Subaru Outback
Need help fixing
I had the same problem a couple years ago with mine. After letting it set for several months, I tried to plug it in again after moving into another house. All of a sudden, it started working again. That was 1 year ago, but just last week...it did it again. I noticed that it does this if it is left on for an extended amount of time (my wife goes to bed at night and leaves it on). I cannot find anything on how to fix it, and no warranty assistance from RCA. I'm purchasing a Sony today, but will hold onto the RCA in case it decides to work again.
Sep 29, 2006 | RCA RT2380 System
TV shuts off after few minutes
tap it on its side then try to turn it on and see if it stays on if it does bad solder connections
Aug 11, 2006 | Sanyo DS31520 31" TV
Radio Communications Logo
104 people viewed this question
Top Radio Communications Experts
Anthony Ward
Anthony Ward
Marvin
Marvin
Are you a Radio Communication Expert? Answer questions, earn points and help others
