Hello, I broke the screen of my camera kodak easy share 813 C following a small crush, I followed everything step by step as shown on the site but kodak support! I mounted the new display that does not work, it is only a white screen (backlight) with intermittent black vertical stripes and horizontal parts. for the rest of the camera seems to work well takes pictures and puts in focus even if I can not see the photos I took. thanks in advance for the help
SOURCE: kodak easy share z612 will not turn on to take a picture
When the battery dies, usually the camera will retract the lens if possible. If the battery is so dead the lens can not retract, I would recommend trying to charge or change the battery. Or try to turn the camera on, and then manually shutting it off if you can.
SOURCE: Kodak Easy Share DX 4530 won't hold charge any more.
Yes rechargeables need replacing from time to time (after a few hundred charges) or every couple of years.
You can use standard rechargeables but these wont charge on the dock as there is a little switch in the battery bay which the kodak pack presses.
Standard AAs ar'nt recommended for digital cameras but you should get at least a few shots from a new set of alkalines (maybe not if they are cheapo no Alkaline)
There could be another problem with the camera but if you like the camera its probably worth giving a new pack a try.
If I remember rightly (but check as I don't have a 4530 to hand) the battery you want is a KAA2HR and are available on ebay cheaply if you cant find a low cost one locally
If I can be of further help drop me a line
Best of luck
SOURCE: Kodak Easy Share M873 suddenly not working
What happened is that the camera got turned on in your pocket or somewhere and the lens got jammed trying to open up. The problem is that the outer lens ring is not turning all the way and the camera doesn't fully load.
Solution 1: Put the camera into the charger, press the power button so the green light is flashing, unplug it from the charger. The camera will try to realign its lens. (You might have to do this a few times.)
Solution 2: Manually help turn the outer lens ring clockwise when it turns on.
SOURCE: Kodak Easy Share V1003 camera is frozen. Turned
Your fix could be as simple as cleaning the camera's battery contacts,
or it could be something more serious and expensive. Before you pay
for expensive repairs that you may or may not need, check the Kodak
Help Center by clicking on the link below. It uses a simple Q&A
format to diagnose problems and propose solutions.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
SOURCE: Kodak Easy Share M763 Won't turn on!!
Remove the batteries and clean the battery contacts inside the camera
with a soft cloth (a heavy buildup on the contacts may require cleaning
with a fine wire brush, steel wool, or sandpaper). Remove any residue
that the cleaning leaves in the camera, and then reinstall the
batteries. This clears most power-on problems, but if yours persists,
check the Kodak troubleshooting guide at:
