Loose or bad electric field connectors or a shorted can also be a problem ,or if one of the two carbon brush is shorter then 1 of the 2 electric field coils of the stator is realy bad .
It sounds like the armature is bad. It should have an even dark ring around the bars of the armature commutator where the brushes ride. If one or two of the bars is discolored above and/or below that it could easily be bad. It could also be pitted between a couple of bars. Normally the space between the bars is even all the way around and nice and "clean cut" looking. If you have access to an armature growler you can test the armature. Hope that helps.
