SOURCE: My washer does not wash the clothes or go through the spin cycle.
It sound like a belt problem. Try to move tub manually first, in case it move smoothly -open the front panel, the belt should be between the motor and the drive pulley (lower front). In case it torn or not in its place, you should replace it. In case it doesn't move smoothly - maybe that a sock or other piece of clothing get between the clothes tub and the outer tub and prevent tub's spining. If this is the situation, it should be removed. Good luck !!
SOURCE: GE front load washer (clothes)
THANK YOU. for those of you with a screw driver, here are the photos on how to.
It takes a philips screw driver and 20 minutes. The white screws may
not align perfectly but don't worry, just get them to go back in the
hole(no harm done).
I'm going to admit it was my wife that found this fix, so now I give the step by step photos.
[IMG]http://i26.tinypic.com/23upff6.jpg[/IMG]
Small white screws (3 in total)
[IMG]http://i30.tinypic.com/69n9eh.jpg[/IMG]
cover "falls" off
[IMG]http://i29.tinypic.com/24erogl.jpg[/IMG]
Unscrew the lint trap (turn to the left)return when clean to hand tight
[IMG]http://i32.tinypic.com/9uralw.jpg[/IMG]
Bob's your uncle and a freebee for CMKX'rs.
Hub and wife team.
SOURCE: GE WASHER SPIN OUT PROBLEMS
Sounds like the suspension for the drum is having problems - there are usually springs holding the drum up and acting as shocks - one of the springs may have come off during an unbalanced load.
SOURCE: GE top loading washer does not spin out water
The belt could be broken, if not. Unplug washer for 2 minutes, plug back in, open and close lid 7 times, this should reset electronic motor.
SOURCE: Brand new GE Profile leaves clothes soaking wet
It is under warrenty call the store where you bought it and have them look at it. If you mess with it it will void your warrenty, belt may not be working or transmisson may not be shifting. The house call will be at no charge.
Testimonial: "thankyou for the help, I thought I had just made a bad buy. They sent someone out right away and it turns out this particular machine had a bad part."
