Question about Motorola Mobility H730 Bluetooth Headset
BLINKING RED LIGHT WHEN TRYING TO CHARGE UNIT
I cannot get my bluetooth to stop blinking red when I try to charge the unit and it will not connect to my phone. What can I do to fix this problem?
    New Friend:
I fixed this problem by connect it on the charger,hold +and - keys together for 10 seconds,it started to charge and work well.
Posted on Jan 27, 2015
  • Joe Karbon
    Joe Karbon Feb 06, 2015
    There isn't a + and - on the H270. Just on off, volume, and power.
  • fix_it_steve Aug 29, 2018
    I had to hold the + & - (volume buttons) while plugging in the charger and it started to charge. Not exactly your instructions, but it worked! Would not have tried this without your suggestion... Thanks!!
  • Official Brand Answer
  • 3,100 Answers
Have you tried other chargers?
Mark
Motorola Support
Posted on Jul 31, 2014
  • Joe Karbon
    Ive tried a couple chargers. Even had it on the USB to my PC, same result.
Anonymous
SOURCE:
Anonymous
SOURCE: Battery replacement
Oh, I found it!
What comes off is the T-shaped chrome piece on the topside. To pry it off, start at the blunter end of the H500, on either side of the USB port. And note that this chrome piece is just a veneer, sitting on top of the black (in my case) plastic housing.
This web page shows and discusses the disassembly process, on the way to reusing the H500 innards for something else:
http://badacetechshow.com/BT%20Hat%20Pg.2.html
See ya...
-- Mark
Posted on Jan 01, 2008
jmgldsmth
Jim Goldsmith
  • 2005 Answers
SOURCE: The Motorola H800 bluetooth headset doesn't charge or turn on. While charging it just displays blinking green light
open and, replace the rechargeable batteries
Posted on May 29, 2009
Anonymous
  • 23 Answers
SOURCE: My motorola h721 keeps blinking red.
if you didn't pair your phone up yet, that could be why. Hold all 3 buttons down for 10 sec. should go solid blue, then pair your phone cause its in discovery.
Posted on Aug 19, 2009
Anonymous
  • 18 Answers
SOURCE: headset not charging
Sometimes it takes longer than two hours. Leave it plugged in overnight if you can. The indicator light should go off after fully charging.
Posted on Sep 04, 2009
vanherringto
J. Van
  • 1738 Answers
SOURCE: When I plug my Motorola H710 bluetooth in to
Here's the instructions for charging.
Plug the Motorola charger into the end of
the headset.
The indicator light turns red when the battery is charging. It may take up to 1 minute for the indicator light to turn on. When the headset's battery is fully charged (about 2hours), the indicator light turns green.
From your information, it may very well be that the battery should be replaced if the red light doesn't go off as it should.
Here's a link to the full instructions. I hope this helps.
(Click here)
http://www.motorola.com/Hellomoto/Master%20Lists/Product%20Manuals/Static%20Files/US-EN/H710%20QSG%20EN%20Generic.pdf
Posted on Feb 07, 2010
What if my uproar wireless headphones are flashing red and blue ?
The headphones flash blue when u switch it on.If it flashes blue and red, it means that it is in bluetooth connection mode.So u can connect it with bluetooth devices by switching on bluetooth on your phone or pc.After connecting the red light stops flashing automatically and blue light starts blinking.Hope you understood. :)
May 04, 2016 | Audio Players & Recorders
Tip
Colour full BlackBerry ..If you are a Blackberry user.You must read this
In BlackBerry LED indicator blinks in different colors to deliver different notifications to the user:
Blinking RED: The LED indicator blinks red whenever you have incoming or waiting communication messages on your phone - new email, new call or missed
call,
Blinking GREEN: this is Coverage Indicator light. This lets you know you are connected to a network.
Blinking BLUE:If your phone is connected to a Bluetooth device, such as a Bluetooth headset it blinks blue.
Blinking YELLOW: A blinking yellow light means it is time to charge your BlackBerry
on Dec 15, 2009 | Cell Phones
My headset doesnt turn on, when I plug the charger the red light starts blinking
Could be a combo of low battery and not yet being connected. Charge it overnight and check on it in the morning.
Check out the
Quickstart Guide
Mark
Motorola Support
Dec 31, 2014 | Motorola Mobility H270 Bluetooth Headset
Vibration ane blinking red light
When a call on your phone comes in i will vibrate, flashes red when battery is low. The light will also be red when its charging. It will turn off when its charged.
Mar 09, 2014 | LG HBS-700 Bluetooth Headset
Alternating red and white blinking light on earpiece for afterglow pl-6360 then shuts off. Unit should be fully charged. Help!
Alternating red and white LED colors indicates that it is not detecting an active bluetooth connection. Use the PS3 bluetooth settings to find and reconnect the signal.
Sep 29, 2013 | PDP Pelican PDP PL6360 Sony PS3 Bluetooth...
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
MY LG TONE HBS-730 WILL NOT CHARGE
It is charged when the red light goes out. Press and hold the VOLUME DOWN button for one second and an audible will give you the battery charge level - high - medium - low.
Apr 20, 2013 | LG Tone HBS-730 Bluetooth Stereo Headset -...
Brand new, never used. Plug into wall to charge and just get flashing red light. After 16 hrs on charge, still flashing red and when turn on, screen blinks then shuts down.
check that you have the battery in the correct way
if it has batteries like AA , AAA or what ever the negative terminal of the battery goes against the coil spring so if you have them all facing the same way, that may be why they are not charging
the screen shutting down at this stage would be cause the batteries are flat
of course you could always bet new fully charged rechargeable batteries and put them in correctly to see if the rest works
Apr 30, 2017 | Sylvania SDVD7015 7 in Portable DVD Player
I have a Olympus FE-100. Everything works fine but it will not flash. Blinking red light. Blinking red lightening bolt. I have tried everything.
hi
blinking red light means camera is trying to charge flash circuitry. if you cancel flash mode, you can use taking picture. But if you want to repair, your local repair shop would charge around $35 to 75 depend on what they really want to charge.
Thanks and best regard!
May 23, 2011 | Cameras
Motorola Mobility H730 Bluetooth Headset Logo
4,613 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
