Toshiba 32AV500U 32 in. LCD HDTV Logo
Posted on Jun 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Toshiba LCD TV AV500E Turns off then on every 5 minutes
I have a Toshiba 32 inches LCD TV bought last November. Lately, I noticed that everytime I use it, its power turns off for about 5 seconds and turns on again. This happens at an average of every 5 minutes. Please help...
Anonymous
Level 3:
  • Master 668 Answers
  • Posted on Jun 20, 2009
Anonymous
Master
Level 3:
Answers
668
Questions
Helped
190349
Points
1925
It sounds to me that the Main board is causing the problem. But I would get in touch with Toshiba for a warranty repair. It has a one year parts and labor warranty. It makes it a lot cheaper for the pocket.
Good Luck,
Skyassoc
How can we start a class action law suite against toshiba
No use. Do you think they will respond to your suit.
Poor man!!!!
Hello! I bought a LG 32-inch LCD (32 inch )
My best advice would be to call out your LG service repair engineer, it is most likely the current software in the TV is of an older version & will need to be re-programmed which an engineer should be able to check. This should cure the menu problem.
32 inch lcd tv installing problems
Buy a flat panel bracket.Use a stud finder and bolt to the wall studs
Toshiba Picture Not On
what you suggesting is that the lcd has a good maintenance needs that have to have cold solder or connectors are sulfated
Toshiba regza question
because it is not 1 year old you may return it to the seller for exchange
1helpful
Toshiba 32" HDTV 2002
The power regulators are famous for going bad. The big problem with this TV set is that unless you use the exact regulator from Toshiba, this set will fail time and time again. Even if the regulator IC has the exact same number, it will not hold up. We used to have a shop that was authorized by Toshiba, and we seen this problem many times when customers would say that they had their TV fixed by some local shop and the same problem occured several times. Good Luck
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
