If you want technical support of Dell, you can contact us on Dell Printer Customer Service Phone Number 1-866-877-0191. We are always available with technical experts for your help. For more information, click https://goo.gl/jBhoUv
We are providing technical support for Dell desktop and printer and all other printer brands such as HP, Acer, Brother, Epson, Lenovo, Sony and many more. We have an expert team of experienced and skilled technicians who can help you instantly to fix your problem.
Dell XPS Support for customer any laptop series to resolve issues.
1 8443952200 Dell XPS 13 15 Tech Support Number Gaming Laptop
Do you get any lights fan noise? check the led on the power supply should be green light.
Contact Dell customer support experts by dialing toll free number 1-800-204-4427 for Dell technical support services. Our Dell customer service experts 24/7 are ready to help you.
Dell Technical Support Phone Number 1 800 204 4427 USA Canada
SOURCE: Dell 5100 Dimension - No Power
there are fuses inside psu`s some are solderd and some pop out it i would suggest that u throw the psu away and buy new chances are that it will only cause continues and may even result in
complete mobo failure problems heres a link to a cheap psu http://www.microdirect.co.uk/(3649)400W-P4AMD-quiet-PSU-with-PFC-20-pin-24-pin.aspx or a more upmarket more powerfull http://www.microdirect.co.uk/(11879)ThermalTake-TR2-500W-Black-Silent-ATX-12V.aspx the choice is yours.
SOURCE: Dell Dimension 8300 flashing amber power light and dead pc
it seems *********** board is having problem plz send it for servicing
SOURCE: Power problem on Dell Dimension 5100
plz check the ram and powersupply unit and try to reset the bios
SOURCE: Problems with Dell Inspiron 9400 Video Memory conflict -
This solution is totally incorrect. He is having the problem that many of us face with the GeForce Go 7900 GS and the Inspiron 9400. There is a known issue with eventual overheating and the video card going bad. This is specific to the single-pipeline chip, in which their is a new dual-pipeline style that fixes the cooling/overheating issue that eventually fries the video chip. Dell has not 100% took ownership of this. I am on my fourth fried video card (thank god for the 3-year warranty I got) in which they have previously replaced with the single-pipeline style. This time they are finally replacing the laptop with either a new Inspiron 9400 (better be dual-pipeline chip) or a NEW equivalent laptop.
SOURCE: Dimension 8400 will not boot, very loud fan.
I own & operate a computer reapair store. I recently worked on a Dimension 8400 that sounded like a jet taking off. I removed the heatsink, cleaned the heatsink & cpu, applied thermal grease & reattached the heat sink. It booted up quietly...after testing it several times...the turbo fan, jet engine sound returned! I removed the heatsink and along the upper part of the cpu I could see where the heatsink hadn't made contact with the cpu! I added more thermal grease & reattached the heatsink. It started fine on several attempts before the jet engine sound returned. I tried applying uppward pressure on the heatsink so it would close the apparent gap between the cpu & heatsink and when I pressed the power button...it started up quietly! At least I identified the source of the problem...not sure how to fix it yet.
