SOURCE: prints out 2 labels at once
I've seen this be due to dirty sensor or misconfigured media setting. Clean the sensor in the middle of the edge on the inside and outside of the printer, then if still having trouble - Inside the printer it should tell you that if you are having printing trouble:
You have just made it reconfigure media, and it may know when to stop feeding now.
SOURCE: Zebra LP 2844 printer will not print anything but the test page
possibly not a real LP2844 but an LP2543, a printer mass produced for and used by UPS. refurbishers change the label and sell as LP2844 because they are almost identical.
if it has an AC-AC adapter, it is an LP2543. LP2844 uses a AC-DC adapter, and all LP2844's have USB ports.
SOURCE: zebra 2488-z
Unplug the printer, place your finger on the green button and with the other hand turn the printer back on. Let the light flash four times (flash, flash flash, flash flash flash, flash flash flash flash) then immediately release the green button. The printer will cycle and feed out a couple of labels. Press the green button one more time and you are ready to go.
SOURCE: Zebra LP 2844 Printer Error, Cannot Print
Try this
START
SETTINGS
PRINTER/FAXES
in the pop up window go to
FILE/SERVER PROPERTIES
DRIVERS
SELECT THE MFC5440 DRIVER AND REMOVE
SELEST THE LP 2844 DRIVER AND REMOVE
Now go to www.seagullscientific.com and download the Zebra driver pack, once downloaded run it and install the Zebra Lp2844 to with the USb port.
This should solve the problem, if not please come back.
trevor
Splitting axe is used in wood splitting to split the grain
of the wood. Splitting axe bits are more wedged shaped.
