Washing Machines Logo
F
Fred Rouse Posted on Jan 22, 2014
Hi, the machine just stopped in the middle of the wash cycle. Here is what I can tell you about it, there is power to the on/off switch, both legs of the 120 volt. Control panel has no lights/code ect showing. It appears that there is no power to the control board and it may have crapped out again.. Main line fuses in machine are fine, power at on/off switch. Is there some other fuse, limit switch that would kill all the functions and codes on the main program panel? I can not get any lights or codes to come up on the panel.. The machine is a W20004 washer, serial WM200 9345-034444.
1 Related Answer
beltronic205
Gerry Harvey
  • 1482 Answers
  • Posted on Nov 12, 2009
SOURCE: washing machine stopped mid cycle there is no
Could be mains switch/ Door interlock dead?..If you have multimeter you can easy check..
Machine lost power during wash cycle.
If the electricity does power off in the middle of washing cycles the washing machine will turn off then. Some of the most common problems that will make your washer turn off during mid cycle can include thermostat failure or issues filling up with water for the rinse cycles or even problems with the pump and the hose that can stop your washer from draining the water. You should call a person that fixes washing machines to have a look and see what the problem is with your washing machine.
Washing machine quite during the middle of a cycle.It has no water,doesn't spin,doesn't make any noise at all.The dryer still works so im sure it getting power!Any help is very much appreciated
Check power to controls on washer first. If no power change sockets in wall duplex to rule out bad duplex . Timer would work in at least one cycle mode so we'll rule that out. Door safety switch would cause sudden stop of machine
2answers
I have a Kenmore Washer that stops in the middle of the washing cycle. The water doesn't drain or anything. I have to take all of the clothes out and scoop out 90% of the water and than turn the washer to...
Hi
Thanks for using FixYa. Please check the belt and lid switch or a broken lid switch plunger. Also check the lid switch actuator and the timer. Please replace whichever is required to be replaced.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Machine stopped washing in middle of wash cycle . all lights went out.
hi there....sounds like you've gotr a blown fuse in your plug top.....or a failed door switch........
regards Sir Galahad
9helpful
Washing Machine is not draining in rinse cycle to go to spin cycl
you both seem to have bad lid switches. A bad lid switch will prevent draining and spinning.
Frigidaire washer machine stop in the middle of the cycle
Replace your lid switch.
The machine must have a goodd lid switch to continue timer functions after wash and rinse.
Whirlpool wahing machine LSQ954PW2
Hello lmaichin
Welcome to Fixya
My name is Huum,
You said,
Machine stopped in middle of cycle and is in a froen state. Checked power 115 volts available to the machine. Suspect switch detecting lid opening is defective. Can not even find sensor switch. please HELP!
At this site you will find the diagram you need. Lid Switch is # 11
http://www.pcappliancerepair.com/model-display.php
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
1helpful
Kenmore stacked washer / dryer 2002
hi thanks for the question so your saying your tub is full of water ,did it stop in the middle of the wash cycle or at the end of the wash if its at the end of wash and it doesn, drain then you have a lid switch problem . if thats the case reset your timer as if you want to start a new wash load if it starts to wash your timer is ok replace the lid switch
Top Asko Washing Machines Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
