The oven is stuck with a nonflashing 00:00 with a red "Delay" written. The model number is MGS5752BDS. How can I fix this? I keep kitting "cancel," but I'm stuck on this screen and can not bake.
SOURCE: Maytag MER6772 - Oven bake element not working even after replacing it.
To find service information for your Maytag Model go tothis link
http://www.servicematters.com/
When on this site, click on Maytag Historical Service Library.
Then click on Maytag Service Library.
Click on term and conditions
Click on Literatur by Model
Enter Modle number MER 6772
Clck go
You will be able to print or download the service manual for your model
Your problem may be the bake relay on the clock or wiring.
SOURCE: Maytag Gemini Stove Code F1-4 (bottom door won't open)
F-1 error is a Temperature Runaway. It Maytag's way of letting you know that oven overheated. Nothing you have done but it may have shorted out the oven sensor or the keypad. Check the sensor and see if it's closed. If it's okay, replace the keypad.
SOURCE: maytag performa model per4311acw
The oven's element may be defective. Take a look at the heating element and look to see if there are any unusual 'marks' on the element.
It is a simple fix.
Unplug the stove, unscrew the screws holding the element to the back of the stove, gently pull the element a few inches towards you, pop off the connectors, take the element out and take with you to the store. It is a good idea to take the model nukber with yoy when you go to the store.
To replace, just reverse the steps above.
