I wish to connect my pc to a television. My laptop and tv have the 15pin socket but where is the audio output on the laptop to connect to the audio input on the tv and what will I need. the tv is a Goodman LD3261HDFVT with hole for the audio input. could you help thanks Mr Les Cole My E-mail address is [email protected]
Hi there.
The audio out or headphone jack is located at the front of the laptop and is coloured green.
Get a male to male mini stereo jack ( about 3 meters ) and you will be in business!!
Good luck and thanks for choosing FixYa!!
To be more specific, the output of the laptop is the headphone jack which is your standard mini plug. The other end is possibly the same type plug which goes into the "hole" you describe. Typically, most folks use the mini plug to red/white RCA plugs. And yes, you can easily find all these cables at any hardware/electronics store.
Get a stereo cable - one end male stereo jack(just like any headset used with your laptop) and other end 2 male audio jacks (like normal audio-video cable)
You need to use both side streo cable.one side for out put from laptop and other side for input to TV. you can find easily at the hardware stores.
