Kenmore Oasis HE 27082 Top Load Washer Logo
A
Anonymous Posted on Sep 18, 2017
My kenmore elite washer gives me a f54 code it wont run thru the cycles in the right order, the basket turns freely and i checked around it and nothing there. had a repair man come out for a service call and he told us that the computer board was no good but then we bought another one online and changed it and there is that f54 code again...
Sal De
Level 3:
  • Kenmore Master 2,699 Answers
  • Posted on Sep 30, 2017
Sal  De
Kenmore Master
Level 3:
Answers
2699
Questions
0
Helped
1003093
Points
8029
If its loud in the spin cycle you have a bad tub bearing and your better off replacing the washer to much to repair
2 Related Answers
Anonymous
  • 15935 Answers
  • Posted on Sep 25, 2010
SOURCE: Kenmore Elite Oasis Wash Machine Error Code F54
The F54 fault code indicates that the control board senses high motor current.
This can be caused by excessive friction in the spin basket.
With the washer off, open the lid and see if the basket spins freely.
If not, you may need to remove the basket and check for an item stuck between the spin basket and the outer washer tub.
The second and third images show procedures for removing the basket on the Oasis washer depending on whether you have an impeller or agitator in your model.
If the basket spins okay, then you can follow the technical troubleshooting described in the first image.
This may help you determine the cause of your washer problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Removing Tub, Basket, lint filter: http://media.fotki.com/1_p,srfssgbktsdgrrqxgtqsskgwtqkq,vi/rstsfdwbbxwwdskwfgkxrrdqddwqb/1/1303472/5961857/image5139789143943268173img-or.jpg
Removing basket & Hub: http://media.fotki.com/1_p,sqgwstkfwtfwsqwxgtqsskgwtqkq,vi/kbkbfbkgwxbfdtwrdxkrkggrdrw/1/1303472/5961857/image27197img-or.gif
Wiring Diagram: http://media.fotki.com/1_p,srfssgbdfbbkfwsxgtqsskgwtqkq,vi/rstkrrqkkxwrtdkbbrbxbqdswfffs/1/1303472/5961857/image3973684248966800668img-or.jpg
http://media.fotki.com/1_p,wktkgtrtsbsgwfrxgtqsskgwtqkq,vi/wrskkfsfrxwwqgrkddg/1/1303472/5961857/image35809img-or.jpg
richroth
Richard Roth
  • 9472 Answers
  • Posted on Feb 02, 2011
SOURCE: kenmore elite oasis model 110.27032600 LF error.
The LF error means Long Fill.
When you start a cycle the water should come into the dispensers. If you have a good flow through the dispenser the valves will be okay.
I recommend checking the inlet water screens on the back of the washer. The inlet screens are located on the water valve. To access the screens you will turn the water off and remove the inlet hoses. The screens prevent debris from entering the valve and sometimes over time mineral deposits build up on the screens. This can block the water or slow the water fills down to a trickle. You can pull the screens out and clean them if necessary. Flush the inlets thoroughly with water when replacing the screens. If debris gets past the screens, it can cause the valves to stick open and an overflow of water can result.
While you have the fill hoses disconnected, place the ends of the hoses in a bucket and briefly turn on the faucets to check for proper water pressure and flow from both hoses.
A common reason for an L F (long fill) error on this washer is the drain hose being stuck to far down the drain standpipe.
If the drain hose is to far down the standpipe then a siphon can occur which causes the washer to fill and drain at the same time. This will cause a long fill error.
1helpful
I replaced the board in a Kenmore elite oasis washer and still get the f54 and f68 code. What's next
Hi Tony. Can you provide the model number of your Kenmore? It should be 110.27xxxxxx. We;ll see if we can figure this out. First, check to see if the inner tub spins freely by hand - we want to ensure that nothing is binding it up (like a nylon stocking). Also, after you changed to board, did you press Pause/Cancel to clear all lights? Have you run a self-diagnostic test?
1helpful
Kenmore Elite oasis washer code F54
F54 is a Motor Control Overcurrent.
1) check to see if there is anything between basket and agitator this can cause this error.
2)move the basket .. should move freely
if all is clear then most likely you will need a new motor
2helpful
2answers
F54 code
It is detecting a high current load when trying to turn the tub. Lift the top of the washer by using a putty knife and insert it between the top and front panels about 3 inches from each side, push in the clip and lift the top. You will find a tech sheet glued to the inside of the front panel in a plastic bag. Go to page 3 and look up your error code, it will refer you to page 4, test #3. I explains how to test the motor assembly.
What is F54 on the Kenmore Elite top load washer? Less than 3 years old
F54 = Motor Control Overcurrent
Does the basket turn freely? If not, determine cause of friction.
There is a detailed repair manual inside the machine. If you open the top of the machine with a screw driver in the front you will find the manual on the inside of the front panel. Good luck
5helpful
When water starts coming in, washer gets a F54 code. what should i check?
This is what the fault is telling you:
F54(F54)-Motor Control Overcurrent
An overcurrent condition is either a wiring problem (lower harness) or a motor problem. (I.e short)
F then 54 flashes when the machine/motor control detects high current for the motor module.
Does basket turn freely? If not, determine cause of friction.
If basket turns freely, see TEST #3.
Test 3 is on this link just below mid page:
http://www.appliancepartsquick.com/WhirlpoolCabrioWasherFaultCodes.html
You will also need to perform Test 1 same page to verify any repairs.
Kelly .
2helpful
F50 alarm on my kenmore oasis washer
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
1helpful
Kenmore Elite Oasis HE top loading washer model #110.27082602 gives me error code F50 and doesn't spin. Other blogs tell me that it is possibly a main control board. What do you think?
6helpful
2answers
5helpful
2answers
Kenmore Oasis F54 code
Alexander
vince
