There are no official firmware updates for the S210. The currently available firmware updates are posted at
http://support.nikontech.com/app/answers/detail/a_id/13783
If you do want to update it with some other piece of firmware, simply put it onto an SD card in a folder named "firmware" and plug the card into the camera.
SOURCE: Nikon Coolpix s210 drivers
if the support guy toldy to by a reader i'm sure it's because that was the only solution. more than like ly the driver is obsolete and no longer available. i'm sure that this is not what you wanted to hear but unfortunately when it comes to new electronics versus older computer. there is always 1 or 2 problems that can't be overcome the conventional way. in general terms windows is always updating security patchs or registry fixes and they don't always include alot of the drivers from prior hardware. card readers are not that expensive anymore and probably will save you money and frustration in the long run. hope this helps. please rate this solution and good luck.
SOURCE: nikon coolpix s210 lens error problem occurs when
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope
the advise is useful. please do not hesitate to let me know if you need
any further assistance. Also, please be so kind to let me know if you
found this helpful.
Regards
Andrea
