GE Profile Harmony DPGT750EC Electric Dryer Logo
Posted on Jun 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
GE Profile Harmony Dryer Drum will not turn
I have a GE Profile Harmony 7.3 cubic ft electric dryer that is approximately 4 years old. The dryer heats well but after every few loads of clothes dried, the dryer drum will not automatically turn. If I turn the drum clockwise (usually just a couple of rotations) until I hear light click and then close the door and push the start button, it works fine. I suspect there is some internal switch that is faulty or going bad as the problem isn't consistent (i.e. occurs every time) but is occurring between every 2-3 loads.
I would greatly appreciate anyone with knowledge on how to appropriately diagnose and correct this problem.
Jim Goldsmith
Level 3:
  • GE Master 2,005 Answers
  • Posted on Jun 01, 2009
Jim Goldsmith
GE Master
Level 3:
Answers
2005
Questions
Helped
736994
Points
6152
The inertia switch on the shaft of the drum motor has failed This will require removal of the drum motor
9helpful
My GE Profile Harmony dryer wont dry clothes
I finally had a GE authorized tech come to our house, because we've had the same problem on and off for about 2 yrs. Our's is 5 1/2 yrs old, and the problem was the blower motor, which is hard to get to, and the nut holding the fan in place is also put on going the "opposite" direction. (So lefty loosey, righty tighty doesn't work for this one) The Tech told me in all his years he has never replaced a heater in any of these, and it has 2. The usual problem is the blower motor has gone bad. It's working great now, and it was $470 to fix, but still cheaper than a new one....
Dryer won't heat. GE profile. approximately 5 years old. Tumbles just fine. Vent is not plugged. Would like to fix myself. Thanks
Sounds like your problem may be with the heating coil.
If you plan to try to repair the problem yourself, then the first thing you want to do is unplug the dryer from the electric.
Remove the back of the machine and try to locate the air tube going from the blower to the drum. Normally inside the air tube you will find the heating coil and the thermostats/thermistor.
Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
You can also check the thermostat/thermistor by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the saftey of overheat from the machine.
Good Luck,
Hope this helps
1helpful
The blower and heat are not working my ge harmony electric dryer
If blower isnt working you wont feel any or very little heat in the drum
1helpful
GE Harmony Elec. Dryer Blower Stops working or won't start up
Do this.
press "Home"
press "Help"
press both "My Cycles" and "Back" at the same time and hold them until service mode pops up.
It will tell you what's wrong.
1helpful
Ge profile harmony electric dryer doesn't always heat.
Remove back of dryer and take out the elament shield and replace element don't over strech it start at one side and work it around thank you for useing fixya rate me
1helpful
GE profile dryer is making squeaking noise.
please replace felt around drum thank you for useing fixya RATE ME
2helpful
2answers
DPGT750EC1WW
anyway...
GE Profile Harmony™ 7.3 Cu. Ft. Capacity King-size Electric Dryer with Stainless Steel Drum
Use and Care Manual
Quick Specs
Installation Instructions
hopes that helps...
Top GE Dryers Experts
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
