F12 SPECIFIC FOR LVB2000 INDESIT EVOLUTION / DIALOGIC.
F12: Lack of Display card-Main Card Communication
1. Check the effectiveness of contacts on CNC Connector Card
2. Overhaul 8-way connector on Display card
3. Check continuity of CNC-CN 8 way connector
4. Replace Main Card
5. Replace Display Card
Dado
Hi
The code F12 means the following:
F12 - No mixed fill. It is likely that the water is not turned on at the taps.
Also Error code F12 is indicating a communications error between cards; Error code F12 is indicating a communications error between cards, this can be caused by one of several things. A problem with bad connections, if you can remove and then replace the plug on connectors, check for loose or chafed wires to motor, they can chafe due to tightness of wires, particularly down to the motor.
It is an electrical problem as opposed to a mechanical one.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
