Sears Kenmore Elite 4.5 cu. ft. High-Efficiency Top-Load Washer Logo
A
Amanda Mack Posted on Jan 23, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore Elite front load washer (model: 110 42936200) won't spin. It makes a buzzing/humming sound when it should be spinning. Any suggestions?
The washer went through cycle normally, rinsed and drained clothes, but then it would not spin during spin cycle. There was an error code of "F2".
its222
Level 2:
New Friend:
  • Expert 59 Answers
  • Posted on Apr 04, 2015
its222
Expert
Level 2:
New Friend:
Answers
59
Questions
Helped
23597
Points
139
F2 mean that you have a drainage problem and could be that the pump is clogged. I believe the pump can be accessed from the front of the washer. Also make sure electrical connections are secure. Make sure no hoses are clogged or kinked anywhere.
My Kenmore Elite He4t front load washer is making a terrible noise when it starts spinning the clothes. What could be wrong?
Sounds like the rear bearing. If you hear the noise when you manually spin the drum or if the drum has any movement when you lift up on it then you need major repairs
1helpful
Kenmore Elite HE3 will not spin, sounds like slight gear slipping
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Washer goes through wash cycle but will not drain, spin and buzzs. Time remaining shows in display. Unplugged and plugged back in again and buzzing continue and time still shows in display. Help!
heatman101
2helpful
Kenmore Elite King Capacity wont agitate or spin
Following is the Sears Parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.20952992
Following is the Whirlpool / Kenmore installation and maintenance PDF for top load, direct drive washers. It includes troubleshooting and testing sections for both the motor and capacitor.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
1helpful
Buzzing sound
does it ever give an error code? a common problem on whirlpool made machines is the dispenser arm getting caught when changing positions. This part is in rear of detergent dispenser housing and uses a motor and a arm to select detergent/ softner/ bleach/ and fill. you can remove top (screws on back) to watch this.
Washer won't spin
Kenmore HD top load Elite Pak II will not spin on cycle but pumps water out. Loud buzzing/clicking sound while on spin cycle.
Top Sears Washing Machines Experts
john h
Are you a Sears Washing Machine Expert? Answer questions, earn points and help others
