Question about Ricoh Aficio AP3800C Laser Printer
CODE ERROR SC543 RICOH AFICIO WHAT PART TO CHANGE
6ya staff
SOURCE:
docusultant
  • 58 Answers
SOURCE: code error sc543 ricoh aficio
SC-543
Heating roller fusing lamp overheat
The detected fusing temperature stays at 200 °C or more for five seconds.
Replacetment the PSU. Got it here: http://www.websitetoolbox.com/mb/copierquestions
Posted on Jan 13, 2009
Anonymous
SOURCE: Ricoh aficio 1232c error code sc 543
This is a fuser problem,possibly a dirty thermistor, but try resetting it first.....
Press yellow key
key in 1,0,7
then press and KEEP HELD DOWN the orange key until the screen alters into service mode. (about 5 seconds)
Then switch off the copier with the main orange on/off switch. Located just below the front cover....
Posted on Jan 22, 2009
SOURCE: SC543 ricoh Aficio 1027
• Fusing thermistor defective or out of position
• Fusing lamp open
• Fusing thermostat open
• Poor connection of the fusing unit
Inspect all the elements before mentioned, soon presses total clear (Yellow Key) 1 0 7 and Maintain pressed clear stop key (orange key) more tan 3 sec. Enter SP 5-810 (SC code reset),
select execute, select close. Exit SP mode, turn the main power
switch off then on.
If the problem continuous the problem can be in the Power supply board, can be defective.
Posted on Sep 02, 2009
SOURCE: RICOH AFICIO 650 WHAT DOES
Try changing the termistor, must be damaged. and reset by total clear, 107 and press and hold the clear stop key more of 3 seconds.
Posted on Sep 10, 2009
canontech
Canon tech CROATIA
  • 1219 Answers
SOURCE: i have a ricoh Aficio 3025 all in one, it is now
its temp. or fixing error. try to clear it in service mode.
yellow 197 red when it says SERVICE MODE turn off and on machine, if it does not help you need to call service to replace thermistor, or lamp, or rise temp. ,or ...
Posted on Jan 13, 2010
What to do with error sc543?
fuser error will need to fix fuser first then reset code
Oct 08, 2014 | Ricoh Aficio SP C231SF SPC231SF SP C232SF...
Error sc543 sp c320dn
SC542, SC543, SC544, SC546,
These codes are related to fuser temperature. Make sure that power source voltage are not low. check thermisters, fusing lamps etc. To reset this code press "All clear" yellow key, enter 107 and press the red key for some seconds. Sevice mode will be displayed, enter SP 5-810 (SC code reset) and select "1". Then hold down the Photo mode key and the # key at the same time for at least 3 seconds
Feb 17, 2012 | Ricoh SP C320DN AllInOne Laser Printer
I have a ricoh Aficio 3025 all in one, it is now giving me a fault code of SC543 please advise
Nov 12, 2009 | Ricoh Aficio 3025 All-In-One Laser Printer
The wrench icon is on and code SC543-00 show up in the screen
That code indicates a fuser overheat error or hot roller fusing lamp overheat. Refer to your manual if you have it. Good luck.
Mar 16, 2009 | Ricoh Aficio 355 All-In-One Laser Printer
Press yellow key
key in 1,0,7
Dec 15, 2008 | Ricoh Aficio C811DN-T1 - printer - color -...
RICOH AFICIO 650 WHAT DOES THIS ERROR CODE MEANS SC543-00
Dec 03, 2008 | Ricoh Aficio SP C811DN-DL Printer
Code error sc543 ricoh aficio 3260C
SC-543
May 05, 2008 | Ricoh Aficio 1018D All-In-One Laser...
Ricoh Aficio AP3800C Laser Printer Logo
76 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
