Hi just read your post.Now is the machine full of water? If it is, drain most of the water by hand with a small pot or bowl.When you have removed most of the water pull the machine away from the back wall and lean it back so you can look under neath the machine.To the right of the machine you will see a little black fan,this is the pump.Make sure the power is off at the wall ,now turn the fan clockwise and anticlockwise.The fan should spin freely.If it does put the machine back on the ground and turn the machine on and select a spin cycle and it should start to drain.If it does not drain or the fan is hard to turn please reply and I can help you further.Regards LU.
For water pump replacement i suggest you to check the help link
provided below.
click the link below :----
Water pump replacing procedure for all vehicles?
http://technoanswers.blogspot.com/2011/11/water-pump-replacing-procedure-for-all.html
HOW TO REPLACE A WATER PUMP
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-water-pump.html
How to route Water Pump Belt for 1992 Oldsmobile ?
http://carbeltrouting.blogspot.com/2011/12/how-to-route-water-pump-belt-for-1992.html
How to replace Water Pump on Car ?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-water-pump-on-acura-car.html
How to Remove Water Pump?
http://technoanswers.blogspot.com/2011/12/how-to-remove-water-pump-on-toyota.html
Where is Water Pump located ?
http://technoanswers.blogspot.com/2011/12/where-is-water-pump-located-on-toyota.html
This will help. Thanks.
provided below.
provided below.
