Hi there we have a Fisher Paykel washing machine GW608U we have lights 1-4-6 (right to left read) and beeping at end of cycle, noticed that it is adgertating when suppose to be spinning. we have rang our tech man here switch off and unplug waited 1 min then plugged back in press the water level up button then the power button it beeped and the hold button on the spin section was lit up, that did nothing , then we pressed the up spin button 3 times and that also did nothing. ran on a short was at it still adgertates on the rinse and spin section.
SOURCE: I have a Fisher & Paykel GW608U
Hi just read your posting.Now the error code you have is error code 132,this means you have a single current trip error.This means the wiring to the motor and rotor position senor are faulty or one of the 3 phases on the motor is open circuit, or your motor controller is faulty. Do you have, or can borrow an electrical test meter ?To find the exact cause I can guide you throe the steps to test the machine if you have a test meter.Please reply for further help.
SOURCE: We have a Fisher and Paykel toploader, smart drive
Hi just read you posting.Could you please confirm the fault code for me.1st push and hold the WASH TEMPERATURE DOWN button then press the POWER button until the machine gives you 2 short beeps,then release both buttons.Now press the SPIN UP or DOWN button until the HOLD and SLOW SPIN LEDs are both on.Now the fault code will appear in the WASH PROGRESS lights.Please reply to confirm which lights are lit.Are they the same as your 1st posting?To get back to normal operation turn machine off at the power point.Looking forward to your reply.
SOURCE: My Fisher & Paykel GWL11 Washer starts beeping
Hi
The washer is detecting error while it enters wash cycle. You can try and enter the diagnostic mode & check if it resolves the issue. If it doesn't then you would need check for the fault codes.
To enter Diagnostic Mode turn the power on at the power point and off at the console. Press and hold the WASH TEMPERATURE DOWN then press the POWER button. Smartdrive will give 2 short beeps. Phase 1 & 2 Only press ADVANCE button once.
From Diagnostic mode press the SPIN buttons until the HOLD and SLOW SPIN LEDs are on, (Diagnostic mode level 3). The WASH PROGRESS LEDs will now display the fault code.
Hope this helps... Please post back if you need further assistance.
Daniel
