RESET SERVICE CODE
Reset the machine. If the code doesn't clear then you either have a fuser code which may or may not be an issue. It has to be set differently. Turn machine off. Hold utility. turn machine on while holding utility. It will bring you to trouble reset screen. Click button on screen and reset the machine. If code comes back, you have a broken part of some sorts. Whats error code?
SOURCE: konica minolta biz hub C250 need to reset admin code URGENT
you cannot overide the administrator password on the konicas the default password is 12345678 try that
SOURCE: i have a c652 biz hub keeps coming up waste
To replace the waste toner box, open the front door above the paper drawers. The waste toner box is on the left hand side (usually). Your supplier should have supplied an extra waste toner box. Slide out the 'full' toner box. Replace with an empty one. This should register that you have installed an empty waste toner box. If not, turn off the copier and after a minute or two, turn on the coper again. [If you want to be environmental friendly, the toner box has a small slide cover approximately 1-2cm long (usually on the upper face at the rear as you remove it). Place this end in a plastic bag, slide open this 'cover' and rotate the toner box 180° so this is facing down. Care needs to be taken to prevent the 'waste toner' from flying everywhere. Gently agitate the box until all the waste toner (a grey color) has spilled out. (Approximately 600-800gms) Carefully seal the bag and dispose. An industrial vacuum cleaner can be used to remove the residual toner, clean down the waste toner box with a soft rag and it is ready to re-use.]
