Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
Posted on Jun 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sony kf-50we610 power led flashes red 5 times
My sony kf-50we610 tv power/standby led flashes green a few times upon turning on then switches to red and flashes 5 times repeatedly.
Mando Mojica
Level 3:
  • Master 643 Answers
  • Posted on Jun 02, 2009
Mando Mojica
Master
Level 3:
Answers
643
Questions
0
Helped
299008
Points
1928
Needs new lamp or the fan is out.
  • 1 more comment
  • Mando Mojica
    Mando Mojica Jun 02, 2009
    how was this inapropriate
  • Anonymous Nov 30, 2012
    its the bulb. just had the same problem. I just changed the bulb 5 months ago too....got a bad bulb. The place where I purchased the new bulb from replaced it since it was under warrenty (just bought 5 mo ago). Apparently, this is coomon....bulbs get misshandled during shipping and can shake small parts. i went through Shop Jimmy.com...what EXCELLENT customer service. i had te new bulb in 2 days for free
  • James P Smith
    James P Smith Apr 09, 2022
    Melissa, I don’t understand what you mean by a bad bulb. I’ve taken the back off of mine and I don’t see a bulb. My model is a Toshiba 49L621U. I may be in the wrong post.
TV turns itself off, then on automaticlly
The fan should run for a few minutes after shut off to cool the lamp down.
If I read and understand correctly somewhere in the cycle you are getting 5 red blinks? that is an error code........
Either you or I can Google the model number of the set with 5 blinks.....or visit the Sony site to see what it means.....
Sony LCD Model KF-60WE610 lamp was replaced and then it shortly after stopped turning on. Blinks Green 6 times then Red 6 times Please help!
For Sony Model KF-60WE610, KF-50WE610, and KF-42WE610, the Diagnostic Code of power light indicator flashing 6 times green, then flashing 6 times red (6 red etc), means you need to replace part number A-1302-272A G1 BOARD, COMPLETE. See Sony Service Manual, 4. Chasis-1 at part Ref no. 103. The Power Board sits vertically in two slots on the left side of the electronics board. 4 wire connectors to remove when replacing. This component fits all 3 KF models listed above.
15helpful
2answers
Sony LCD KF-50WE610 no picture-red light blinking
3 times standby red light blinking shows that lamp cover has not been placed back properly after lamp replacement.
Make sure lamp cover, (the first thing that you removed to replace lamp in tv) is fixed securely then turn tv On.
4helpful
Sony KF-60WE610, green light flashes few times and return to red, what could be the problem TV only five years old
Your lamp (back lighting) is burnt out and need replacement. The instructions are in your manual
Sony 2004 KF-50WE610 power/standby button flash doesnt turn on
turn ur tv off for awhile turn it back on it should work,But ur video board it was bad now it dead.
1helpful
SONY GRAND WEGA KF-50WE610 can't turn on TV screen.
Ths 5 blinks usually indicate an AKB problem. There is a break in the video path. I'll look up your specific model and post the results here. Please update this if you wish to attempt the repair yourself.
Thanks,
Dan
1helpful
Sony KF-50WE610 flashing power/standbylight
Its small board with few connectors and easy to replace.
You can buy required part from Part Store. You may see image of ballast supply there.
2helpful
Sony kf-60we610 stand by blinks 5 times
Hey there,
I've had my Sony KF-50WE610 for approx. 4years now and have just experienced the prob you described (though I didn't think to count the number of red blinks). I called Sony TV technical support (888-772-7669, #3 for TV/digital cameras, #1 for TV, then #1 again I think). They said that if the power/standby light blinks 5x, that means there's something wrong with the lamp driver and service will be required. Needless to say, I better go home and count my red blinks! Good luck, I hope this helps a bit. Have a happy and safe holiday!
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
